Outdoor Speaker Location - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 05-31-2008, 08:50 AM   #1
jelly's Avatar
Rewards Points: 330
Outdoor Speaker location
Is the location of outdoor speakers as important as the positioning of indoor speakers? I've seen them about 3 ft off the ground but my first thought was to put it 9 ft up. Just wanted a second opinion before I drilled threw the side of my house. THanks
Heres a pic of the back of my house. To the left is the patio furniture.
jelly is online now   Reply With Quote
Old 06-01-2008, 01:44 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
To the best of my understanding on this subject, speakers should be at a height of about ear level in normal conditions. Meaning, if it's in a place where people mostly stand then 5-6' if sitting 3-4'.
wirenut1110 is offline   Reply With Quote
Old 06-01-2008, 07:17 PM   #3
jelly's Avatar
Rewards Points: 330
Makes sense to me, thanks wirenut.
Old 06-05-2008, 09:14 AM   #4
I think wirenut is right.
I have a neighbor who has outdoor speakers mounted about 10 to 12 feet high on the back of his house and when he has the volume set where you can hear it good, so can most of the other neighbors.
He is contemplating lowering them closer to ear level so the volume wont have to be turned up as loud.
I'm just glad he doesn't like opera or Lawrence Welk. (I'm not saying either is bad, just bad on my ears!)
kjwoodworking is offline   Reply With Quote
Old 06-05-2008, 02:49 PM   #5
Rewards Points: 1,466
Unlike a Family Room , or such, where the tweeter should typically be placed aprroximately at ear level, the reason for having outdor speakers mounted higher is that you do want to broadcast the sound to a larger area.
ktkelly is offline   Reply With Quote
Old 06-19-2008, 12:54 PM   #6
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Depends on the speakers. The true acid test would be to test them at different locations. Different frequencies transmit differently with reflections. Also the enclosure design should be factored in. I like good sound quality without bothering anybody and there is a medial point if you try. Ground level gives great response, actually.
And please - if you and your friends are gonna get drunk and sing along, LEARN THE LYRICS. (My neighbors are horrible singers, lol!)
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 06-20-2008, 03:10 PM   #7
Rewards Points: 150
generally speaking higher frequencies are directional unlike lower frequencies. That why many speakers have moveable tweeters so you can "aim" them, and subwoofers can be hidden. This is very noticeable when you move to the side of a speaker. So to get a more "clear" sound, often associated with the higher frequencies, the speakers should be "aimed" as well as possible at the listening area.
steve1234 is offline   Reply With Quote
New coaxial outlet location shimkc Home Theater 1 01-03-2008 09:55 PM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 01:26 PM
Light switch location ADKstorm Electrical 4 09-10-2007 06:41 AM
Location of a sub panel pepemalinus Electrical 3 04-04-2007 06:34 PM
Drain location off by 1/4" jross Plumbing 24 03-30-2007 06:39 PM
