Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 07-22-2012, 06:45 AM   #1
raylo32's Avatar
Old Mitsu 27" tube TV hums while off
I have an old tube TV in my kitchen eating area that works just fine... except it recently started humming after it gets turned off. So every time I turn it off now I unplug it. Is there an easy fix for this? I assume it needs a replacement relay or somesuch? I am fairly comfortable going in there and working on it having once upon a time gone in to jumper out the picture in picture based on a website how-to when it failed.
Any of you guys have the solution?
raylo32 is offline   Reply With Quote
Old 08-26-2012, 08:12 AM   #2
Dorf dude...
shumakerscott's Avatar
Take a look at the capacitors in the power supply. If they are bulging then replace them. dorf dude...
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 08-26-2012, 08:37 AM   #3
raylo32's Avatar
Thanks for the input. Where is the power supply typically located? I assume it is just a section on the circuit board?
Live long and prosper.
Old 08-26-2012, 08:58 AM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
Bad flyback transformer is what is causing the hum, not capacitors.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 08-26-2012, 09:05 AM   #5
raylo32's Avatar
Where is that located and are replacments available, OEM or generic?
Old 08-26-2012, 09:23 AM   #6
raylo32's Avatar
OK, I googled them and found a site that lists a bunch. I need to open my TV up and see what I have. But at these prices and depending on which one it is the TV may be "totalled".
http://www.technotronic-dimensions.com/Products2-2.html
Decommissioning Knob and Tube Perry401 Electrical 3 01-19-2012 08:09 PM
Knob & Tube -- Cellulose Insulation rlowe82 Electrical 23 11-08-2011 01:03 PM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 08:23 AM
Water tube to fridge... Wolf_22 Appliances 9 04-04-2008 01:36 PM
