-   Home Theater (http://www.diychatroom.com/f12/)
-   -   Old Mitsu 27" tube TV hums while off (http://www.diychatroom.com/f12/old-mitsu-27-tube-tv-hums-while-off-151116/)
raylo32 07-22-2012 05:45 AM
I have an old tube TV in my kitchen eating area that works just fine... except it recently started humming after it gets turned off. So every time I turn it off now I unplug it. Is there an easy fix for this? I assume it needs a replacement relay or somesuch? I am fairly comfortable going in there and working on it having once upon a time gone in to jumper out the picture in picture based on a website how-to when it failed.
Any of you guys have the solution?
shumakerscott 08-26-2012 07:12 AM
Take a look at the capacitors in the power supply. If they are bulging then replace them. dorf dude...
raylo32 08-26-2012 07:37 AM
Thanks for the input. Where is the power supply typically located? I assume it is just a section on the circuit board?
gregzoll 08-26-2012 07:58 AM
Bad flyback transformer is what is causing the hum, not capacitors.
raylo32 08-26-2012 08:05 AM
Where is that located and are replacments available, OEM or generic?
raylo32 08-26-2012 08:23 AM
OK, I googled them and found a site that lists a bunch. I need to open my TV up and see what I have. But at these prices and depending on which one it is the TV may be "totalled".
http://www.technotronic-dimensions.com/Products2-2.html
