Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 05-31-2010, 01:38 PM   #1
OK to mount flat-screen TV on plywood
I bought a Chief PDRUB mount to mount my 50" flat-screen TV. The instructions say it must be mounted to two studs. However, there are no studs in the location where I want to mount it. Instead, behind the wall is plywood. Is it OK to mount it to plywood?
bzc10 is offline   Reply With Quote
Old 05-31-2010, 03:07 PM   #2
It was a dark and stormy
Yoyizit's Avatar
How thick?
Does the grain on most of the plies run vertically?
Will you use through-bolts?
Old 05-31-2010, 04:38 PM   #3
I don't know the thickness or if the grain runs vertically. I know there's plywood because I took video of the house while it was being built, and you can see the plywood but no studs.
I'm not sure what through-bolts are. The mount comes with lag bolts. Are these the same?
Old 05-31-2010, 06:42 PM   #4
Yoyizit's Avatar
With no studs I don't know what's holding up your house.
Bolting it with a nut, bolt and fender washers through the plywood would be stronger than using lag screws.
Probably you need to add studs at that location. The plywood would probably bend so much it would be visually disturbing.
Old 08-21-2010, 07:44 AM   #5
The same screws you use to mount the TV to studs will suffice for mounting the TV to 1/2 inch or thicker plywood, except that the smooth part of the screw nearest the head must not go so far in as to touch the plywood.
For thinner plywood use more of the same kind of screw (three for every two originally called for; round up), or use Molly bolts or use bolts with washers behind as suggested above. The extra screw for each grouping should be as high up (vertically) as possible.
Now you need to know what the plywood is attached to so the whole wall doesn't come down.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 08-24-2010, 07:24 AM   #6
DIY Hack
Mr Chips's Avatar
When you say your house has plywood wall,
i am thinking perhaps you really saw and made videos of the exterior sheathing, and that there are in fact studs on the other side
Try running over your walls with a good stud finder, or upload your video to youtube and post the link
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-26-2010, 11:24 PM   #7
There is almost no reason I can think of that there would be plywood and no studs. Even if there were plywood, it should be mounted on studs.
onetec is offline   Reply With Quote
Wiring for a wall mount flat screen Badfish740 Electrical 4 01-13-2010 08:21 PM
flat screen outside? tripflex General Discussion 16 09-22-2009 05:06 PM
Glass mirror over fireplace, any ideas how to install flat screen TV? dynamo Building & Construction 1 07-25-2009 10:02 AM
Uneven Studs and mounting a Flat Screen -Please Help! SassyLilRedhead Home Theater 6 01-22-2009 10:33 PM
Tripling Plywood for a 150 lb Plasma TV "corner" mount carlosakrami General Discussion 9 09-12-2007 11:16 PM
