Odd Stud Size And Location? Help? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 02-21-2011, 04:02 PM   #1
Odd stud size and location? help?
I am trying to mount a 42" flat screen above my gas fireplace and mantle. with my stud finder i have found the middle stud to be the standard 2x4 at 1.5 inches in width. The other 2, one on each side are add width's at 3-3.5 inches... They are also 20-20.5 inches on each side of the middle stud? Any ideas on the werid configuration and why the difference in stud width? I want to mount to 3 studs and need to figure out how to get a brack large enough since it looks like my to width across the board is 4o inches or so... any ideas?
mbrown4844 is offline   Reply With Quote
Old 02-21-2011, 04:32 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The studs are placed twenty-four inches on center but the two (one left, one right) of the center stud are turned on to their flat (3-1/2") side.
Mark the center stud, then from there mark twenty-four inches to the left and twenty-four inches to the right and you should be OK. That should put you in the center of each of the three studs.
Of course that puts you 48" from extreme left to extreme right.
People do weird things without explanation sometimes. Go figure.
XXX
Old 02-21-2011, 05:45 PM   #3
Thanks for the info... That makes sense now... My next problem in that I need bracket that spans 42 inches at least and most of the ones i am seeing are 34-37 inches across... Any ideas how to mount this safely with the configuration of these studs?
Old 02-21-2011, 05:54 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It depends on exactly what you are doing or wanting to do. You can buy a product called Uni-Strut. It is basically a U-shaped steel channel with holes in it for various mounting arrangements. The stuff is kind of industrial looking which is where it is mainly used but you could paint it.
There should be a way to work with it.
XXX
Old 02-28-2011, 08:10 AM   #5
Rewards Points: 152
Could be a stud on it's flat side...or a stud doubled up...ie. two studs together.
piste is offline   Reply With Quote
Old 02-28-2011, 05:06 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
piste: "Could be a stud on it's flat side..."
XXX
Old 02-28-2011, 05:37 PM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Originally Posted by Bud Cline View Post
I think he was saying, he agrees with the you, that the studs are turned flat, OR that they are in the normal configuarion, only doubled up (sistered), which was my first thought as well
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 02-28-2011, 07:29 PM   #8
Rewards Points: 152
Um...yeah exactly. What I was saying was....What Bud said "could" be correct (and I give full credit to him for that because I would never have thought of that possibility)....OR....(more likely) it's two studs in normal orientation doubled up. And were I to bet...I'd put my nickel on the latter. Generally speaking studs are much more often doubled up than flipped ...in my very limited experience. If your stud finder is showing closer to 3" "thickness" then that's a strong indication its two studs doubled up...but if showing closer to 3 1/2" ...then one stud on its flat side....though we all know stud finders can be tough to get that accurate a reading off of. good luck.
Old 02-28-2011, 07:39 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Old 03-01-2011, 09:37 PM   #10
Rewards Points: 530
Might as well add the possibilty of some sort of closet or alcove on the other side of that wall. But I guess that would be closer to a 6" reading by the stud finder.
Why would someone turn a stud sideways? To avoid cutting holes for a drain or wtaer lines?
Be careful drilling holes.
Subpanel location and size PhillyRyan Electrical 5 08-18-2010 03:49 PM
Wire size 220 /3600 w toaster deck hand Electrical 4 04-27-2010 06:11 PM
Number, Size, and Location of Celing Vents GeauxCajuns82 HVAC 7 11-13-2008 10:40 AM
Rough in / stud wall location help? Taipans Building & Construction 11 06-18-2008 09:41 AM
