Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 01-16-2010, 03:23 PM   #1
Question
Need advice on wall tvs
So I got this 32" vizio that I use to pretty much do everything pc/xbox360/ps3 and ps2. What I want to do is hang this tv on the wall corner.
Here is the tv:
And this is where I want to tv to be on this wall corner:
So I went to vizio site and found out what kind of wall mount I would need. But here is the thing how is this wall mount going to be attached on to the wall? Do I have to find out if there is wood behind that corner of the wall? I do have to get a good support to hold up the lcd.
deziking is offline   Reply With Quote
Old 01-17-2010, 08:38 AM   #2
Just use a single arm mount. You can hit the first stud from the corner and position the TV near the corner.
http://www.monoprice.com/products/pr...seq=1&format=2
jerryh3 is offline   Reply With Quote
Old 01-17-2010, 02:38 PM   #3
Jack of all - master none
hyunelan2's Avatar
That's very similar (if not the same) to the mount I used to put a 32" Vizio up in a corner at my parents' house. Also check eBay prices - sometimes you can grab a really good deal on mounts, though monoprice is reasonable also.
hyunelan2 is offline   Reply With Quote
Replacing large retaining wall notfromaroundhere Landscaping & Lawn Care 6 12-17-2008 01:30 AM
Removal of interior wall Bobb G Remodeling 4 09-15-2008 02:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
