Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 01-13-2007, 09:57 PM   #1
Mounting a TV "IN" a wall
I am trying to mount a TV in a wall between my kitchen and my living room so that I can watch the TV in both rooms by spinning the TV. My plan is to have a picture mounted on the back side of the TV to cover up any wires. The wall is made out of plaster and might be load bearing. I dont have any experience with plaster walls. Are there studs in plaster walls? will I be able to frame in this section? What should I use to rotate the TV in the middle? Will the wall support 75 pounds or so? Any help or suggestions and ideas I would really appreciate. Thanks, Dave
dchutnik is offline   Reply With Quote
Old 01-17-2007, 12:07 AM   #2
hire somebody, not to be blunt but those are big ?s your asking
it is a cool idea i rented 2 for the money last night & they had one mounted like that.. very sweet
POOLMANinCT is offline   Reply With Quote
Old 01-17-2007, 06:06 PM   #3
with Mrs. Jeep
JeepCop's Avatar
Yes, there will be studs in the plaster wall. If you don't know if the wall is load bearing or not, you had probably better hire the job out. IMO, you don't want to take on that big of a project without knowing exactly what you are doing.
JeepCop is offline   Reply With Quote
Old 01-25-2007, 10:05 PM   #4
Its gotta be cheaper just to buy two tvs!
elementx440 is offline   Reply With Quote
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
mounting 18" tiles to bathroom wall? ako1d Remodeling 3 02-07-2006 05:19 PM
