Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 11-16-2011, 05:36 AM   #1
DHS
Question
Mounting projector on window header
I was wondering if it is okay to mount a front projector using a wall mount on the window header. Total weight of projector plus mount is around 20 pounds so I don't think it should be much of an issue, but I also don't want to put stress on the window over time.
Any input would be appreciated.
DHS is offline   Reply With Quote
Old 11-16-2011, 06:48 AM   #2
the Musigician
DangerMouse's Avatar
I agree. I do not believe it will cause any problems any time soon.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 11-16-2011, 02:09 PM   #3
DHS
Thanks DM. My only concern is mounting in the middle of the header will not cause sagging in the long run.
Old 11-16-2011, 02:11 PM   #4
Tileguy
Bud Cline's Avatar
The header would twist long before it would ever sag and it ain't going to twist.
Go for it.
The Following User Says Thank You to Bud Cline For This Useful Post:
DangerMouse (11-16-2011)
Old 11-16-2011, 02:39 PM   #5
the Musigician
If your 'long run' is a couple hundred years, then yes, I'd be concerned.
I think you'll be fine though.
DM
Old 11-16-2011, 03:24 PM   #6
DHS
LOL. Thanks guys. Definitely puts my mind at ease.
Old 11-19-2011, 11:05 PM   #7
Ironlight's Avatar
The window header is designed to support a lot more weight than the projector. The vertical forces on it from above could well be quite a few hundred pounds. A 20 lb. projector is not going to bother it in the least.
Ironlight is offline   Reply With Quote
Egress Window Header? ottoguy Building & Construction 3 09-08-2011 11:22 PM
converting wood to steel for window header Dan S Building & Construction 7 05-22-2010 02:44 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 05:15 PM
