-   Home Theater (http://www.diychatroom.com/f12/)
-   -   Mounting projector on window header (http://www.diychatroom.com/f12/mounting-projector-window-header-123625/)
DHS 11-16-2011 04:36 AM
I was wondering if it is okay to mount a front projector using a wall mount on the window header. Total weight of projector plus mount is around 20 pounds so I don't think it should be much of an issue, but I also don't want to put stress on the window over time.
Any input would be appreciated.
DangerMouse 11-16-2011 05:48 AM
I agree. I do not believe it will cause any problems any time soon.
DM
DHS 11-16-2011 01:09 PM
Thanks DM. My only concern is mounting in the middle of the header will not cause sagging in the long run.
Bud Cline 11-16-2011 01:11 PM
The header would twist long before it would ever sag and it ain't going to twist.:)
Go for it.:)
DangerMouse 11-16-2011 01:39 PM
If your 'long run' is a couple hundred years, then yes, I'd be concerned.
I think you'll be fine though.
DM
DHS 11-16-2011 02:24 PM
LOL. Thanks guys. Definitely puts my mind at ease.
Ironlight 11-19-2011 10:05 PM
The window header is designed to support a lot more weight than the projector. The vertical forces on it from above could well be quite a few hundred pounds. A 20 lb. projector is not going to bother it in the least.
