Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 11-25-2008, 11:11 AM   #1
Mounted my TV this weekend and might have done it to high!!
Hi All:
So this weekend I finally got around to mounting my 37" LCD on the wall in the living room. It turned out great, was able to put the cable box and dvd player in the closet and conceal all of the wires.
Now that it is done, I think i mounted it too high. How high has everyone else mounted theirs? I will measure and take pics when I get home.,..
HELP!!!
tmcguirk is offline   Reply With Quote
Old 11-25-2008, 11:17 AM   #2
freshman
Pipeline's Avatar
it is said somewhere that you shud always look straight to the tv eyeball to eyeball [know what I mean?].
or better yet lower the tv below your eyes
like for instance your sofa, you sit down and the middle of the tv shud be lower than your chin
because......... it strains your eyes way less [ keep your eyes mositured]
your eyes becomes very dry if you look up [just the eyes, not your head]..
just pointing that out
Pipeline is offline   Reply With Quote
Old 11-25-2008, 11:27 AM   #3
I think that is the biggest mistake when people are mounting flat screens. I've seen some that are almost up to the ceiling. It should be at eye level or slightly above.
jerryh3 is offline   Reply With Quote
Old 11-25-2008, 11:28 AM   #4
one other question is, is there anything that I should be concerned about with the wires in the wall, or boxes in the closet?
Old 11-25-2008, 12:31 PM   #5
Workaholic's Avatar
Does your wall mount have a tilt on it?
Sean
Workaholic is offline   Reply With Quote
Old 11-25-2008, 12:34 PM   #6
yes it does. I paid a bit extra, but think it is worth it. It has 12 degrees of possible tilt in either direction. It is Sanus.
Old 11-25-2008, 03:46 PM   #7
freshman
Pipeline's Avatar
When I get my new Sony HDNA flat screen I will not put it on the wall
I will lay it upright on a table that is like an entry way cherry table
The surround sound speakers shud be up thou
Old 11-25-2008, 07:06 PM   #8
Workaholic's Avatar
The reason that i asked is i have our 42" flat, 44" high on the wall from the floor. I have the tilt mount and it is a perfect height for us. Of course i have 3 small kids and that was a deciding factor on why we wanted it at that height.
Sean
Old 11-25-2008, 08:43 PM   #9
i just measured it again and it is 47" from the carpet up to the bottom of the TV. It might be a bit too high, but we are repainting the entire living room soon, so may patch up the hole and re-do it....ugh....first time for everything I guess...
Old 12-04-2008, 06:05 AM   #10
It's all depand you. you can decide what is the proper place for your home theater and it also be comfortable too
Last edited by AtlanticWBConst.; 12-04-2008 at 08:24 AM. Reason: SITE RULES VIOLATION: Advertising Link Removed from Signature
PaulAdman is offline   Reply With Quote
Old 12-04-2008, 06:25 AM   #11
BUILDER / REMODELING CONT
buletbob's Avatar
I agree it all depends on you. I have my 42" LCD mounted 54" off my bedroom floor. and with a slight tilt. there really is no set height as far as I'm aware of. I have seen them mounted over fireplaces quiet a few times, that's over 4' ! BOB
Old 12-04-2008, 10:54 AM   #12
thanks for all of the replies everyone. My wife and I are starting to get used to it, but still may rehang when we paint the living room this winter.
Thanks!
