Long Run From Receiver To TV-What Wire - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 08-25-2010, 08:10 PM   #1
Long Run from Receiver to TV-What wire
I am setting up my A/V reqipment in a closet about 50 feet from my TV. An HDMI connection from AV receiver to TCV is impractical. How can I get 1080P to my TV? Which cable, connectors etc to use
bohaiboy is offline   Reply With Quote
Old 08-25-2010, 09:00 PM   #2
Thrasher
You can only get 1080P through HDMI (xbox 360 is the only device that passes 1080P through component video cable).
Component cable gets you up to 1080i.
Why is the HDMI impractical?
Lulimet is offline   Reply With Quote
Old 08-25-2010, 10:40 PM   #3
The cost for running it 50-75 ft. I haven't seen HDMI cables that long either, or am I missing something?
Thanks for the reply
Old 08-25-2010, 10:52 PM   #4
Thrasher
Blue jeans cable are highly rated and don't cost an arm an a leg like Monster Cable. http://www.bluejeanscable.com/store/...hdmi-cable.htm
Or you can go cheaper with the Dayton Audio cable from parts-express.
20 meter ( 65 ft.) for $55 plus shipping. Can't beat that price in my opinion.
http://www.parts-express.com/pe/show...number=181-812
Old 08-26-2010, 10:08 PM   #5
That's not accurate. Component can go much higher but the manufacturers don't do analog 1080P because the quality is so high and they can't copy right protect the signal. Some TV's DO 1080P on component for gaming. Just an FYI.
onetec is offline   Reply With Quote
Old 08-26-2010, 10:10 PM   #6
Baluns
You can always run 2 cat5E wires and use HDMI baluns. It's much easier to fish and at that length, should be cheaper and more reliable than HDMI.
Old 08-26-2010, 10:16 PM   #7
Thrasher
I did say xbox 360 does 1080P through component.
Old 08-26-2010, 10:20 PM   #8
Funny, I read "You can only get 1080P through HDMI " and I was just trying to clarify. You can run 1080P by component from a computer also and play bluray in that computer, so I guess there are other devices too.
Old 08-26-2010, 10:30 PM   #9
Thrasher
I meant it more in the way that not many devices pass 1080p through component. I have yet to see a bluray player that does, no cable set top box does (I don't know of any TV stations that do 1080P HD) and I don't know if there are any receivers that do 1080P through component.
The OP wants one cable from his receiver to the TV.
Old 08-26-2010, 10:44 PM   #10
You are correct sir. I was just throwing some trivia out there because so many people think component can't do 1080P.
Old 09-03-2010, 10:05 AM   #11
I second that. You can also get component baluns, VGA baluns, for any type of source you need.
However, I recommend sticking with a single HDMI run to keep costs down. Just use a source switcher where all your equipment is located.
Homer
homerb is offline   Reply With Quote
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
Fishing Wire MikeyP Electrical 17 12-01-2008 10:05 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
