#1 |
Leviton 5280 Surge protector receptacle
I just purchased a sharp 60" led and wanted to make sure I had it plugged into a surge protector. I currently have one outlet recessed in the wall near the tv but it's just a regular receptacle.
This leviton is only rated at 720 joules, doesn't seem like it would be good enough for an lcd tv. Would this be ok or should I look for something else? I don't have any room for a big surge protector, wanted something flush with the wall or very small. Would really prefer a receptacle like this as opposed to a cube surge or something. I looked at the Panamax MIW-SURGE but that's going to be too big. Any ideas? |
#2 |
Average Joe/ex-Navy IC3
Yes it is okay. If you own, you could also install a whole house surge. Personally, the panamax is overkill.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
| Display Modes | |
| Getting a 200Amp Square D OQ Panel. What about surge protector? | mudworm | Electrical | 3 | 10-27-2011 03:29 PM |
| New place, no ground in room, expensive computer | pinkmanta | Electrical | 27 | 10-24-2011 02:16 PM |
| lights surge when appliances start. | fromscratch | Electrical | 11 | 08-05-2011 02:20 PM |
| Leviton 8599 GFCI wiring issues | KE2KB | Electrical | 4 | 02-06-2009 09:53 AM |
| Is it a hazard to plug a surge protector into an ungrounded GFI outlet? | CuriousWithQuestions | Electrical | 7 | 02-01-2008 10:04 PM |
