Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 03-30-2008, 12:00 AM   #1
newer than a newbie...
large outdoor antenna
HI THere.
We have just bought a new home (older home of the late 60s) that has a very tall tv antenna outside the house. It's about 30 feet tall.
I figure that instead of spending $50+ for cable, since I don't watch a lot of tv, I could cancel and switch to antenna.
I was wondering if anyone could tell me if I would need to run a cable directly from the top of the antenna to my tv? or does the antenna (the fact that it's grounded on my property) itself automatically ground to something metal inside?
How would I hook this up to my tv/multiple tvs?
Your input would be much appreciated!
mcvane is offline   Reply With Quote
Old 03-30-2008, 01:22 AM   #2
wfischer's Avatar
Don't do it! All TV stations will stop broadcasting analog signals at midnight on Feb. 17 2009, so after that you'll have nothing to watch but snow.
Check this website for more info: http://www.dtv2009.gov/
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape!
wfischer is offline   Reply With Quote
Old 03-30-2008, 07:59 AM   #3
Electrician
You do realize you get free High Def with an antenna, I love mine and best part is its free....
chris75 is offline   Reply With Quote
Old 03-30-2008, 11:49 AM   #4
If there is not a coax running from that antenna you will have to add one.
And if that antenna is a "yagi" it's not going to serve your purposes for very long since it's UHF section is probably very small.
You can replace that antenna with a Winegard SS2000 which should bring in those HDTV channels depending on your location (it's a amplified version you can split the coax and feed more than one HDTV).
Note 1: If you do not have newer HDTV's with onboard ATSC tuners, you will need a down conversion box for each non ATSC TV (available soon, if not now).
Note 2: You will receive a HIGHER resolution picture from this anteena than if you use either cable OR satellite.
There are many here that will give you some seriously wrong advice on this matter. Nothing more dangerous than a DIY that gives out wrong info.
ktkelly is offline   Reply With Quote
Old 03-30-2008, 04:41 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
You do realize, that the OP, just needs to correct the wiring on the one that he has most likely, and if needed, can add an amp. Besides, if anything, who wants to climb up a mast, or pay to have someone do it for you, when most companies have Basic CATV service for under $20.
gregzoll is online now   Reply With Quote
Old 03-30-2008, 05:46 PM   #6
What is the OTA resolution compared to cable/satellite? I thought all three supported 1080i/720p.
jerryh3 is offline   Reply With Quote
Old 03-30-2008, 06:09 PM   #7
gregzoll's Avatar
ATSC-HD is what you are thinking about. NTSC can send 1080i/720p, but would eat up a lot of Bandwidth Spectrum. ATSC-SD is just 480i, not High Definition.
Old 03-30-2008, 09:16 PM   #8
Originally Posted by jerryh3 View Post
What is the OTA resolution compared to cable/satellite? It thought all three supported 1080i/720p.
Both cable and satellite companies use a compression method so the resolution is NOT a full 720/1080 signal. Close but no cigar....
http://en.wikipedia.org/wiki/NTSC
http://en.wikipedia.org/wiki/ATSC_Standards
FWIW:
A NTSC (analog) tuner will not receive and decode digital signal.
Old 03-30-2008, 09:38 PM   #9
Electrician
Why pay 20 bucks every month when you can get tv for free?
Old 05-07-2008, 01:03 PM   #10
Hi All.
I was the original poster to this thread and now the antenna is hooked up!
Basically, I realized that the previous owner taped over the 2 cables that come down from the antenna that is very very tall. One is the cable wire and one appears to be a grounding cable? (correct me if I'm wrong).
Anyways, I hooked it into a line that feeds into my bedroom and voila! I have at least 20 channels that are either crystal clear or decently clear. As another poster said "Why pay for it when it's free?"
I am in Canada and I am not even sure if the Feb 2009 elimination of analogue lines applies. I do get some US channels, but most of the prime time programs are simulcasted on the US/Canadian channels anyways, so that's not a problem for me.
As for the grounding cable that is currently not hooked up to anything, can anyone recommend where I can hook it up to? Somehing metal? I am assuming its purpose is to distribute electricity to the ground in case lightning strikes the antenna.
Thanks!
Old 05-08-2008, 10:22 PM   #11
gregzoll's Avatar
Ground Rod driven into the ground.
Old 07-01-2008, 10:31 PM   #12
Roof Cleaning Expert
You did not say IF the other cable is a coaxial cable, twin lead, or just a wire ?
It COULD be the UHF part of your antenna ?
Some dual element one boom Yagi's used seperate feeds for UHF VHF/FM
Less Loss this way.
As for grounding, the pole going into the ground MAY serve as a ground, depending on the conductivity of your soil.
apple roof cleaning is offline   Reply With Quote
Old 07-02-2008, 10:23 PM   #13
bofusmosby's Avatar
It is true that the old fashioned antennas may not be as good as the new ones for the digital transmission, but here in Tampa, many of our customers are getting great results with their old/standard antennas. We have hooked up a number of digital converter boxes, and with just a few exceptions, show a great picture with not only the only analog, but digital transmissions as well.
As far as the ground wire, if there aren't any pipes close by, I would sink a ground stake 3-4 foot down, and connect it there.
bofusmosby is offline   Reply With Quote
Old 07-03-2008, 12:43 PM   #14
I live in Brandon, and ch 10 is a challenge, all snowy.
BUT, switch into hi def, perfect picture!
Old 07-03-2008, 07:59 PM   #15
bofusmosby's Avatar
I hear that about channel 10. Its tough to get with rabbit ears. I just broke down and got basic cable again. For the price with the phone, unlimited long distance, and the high-speed internet connection, its costing me about $17 more a month. I originally had my cable disconnected back in 92. The $24 was getting to be too much!
large leaking tar flat roof erbilliards Roofing/Siding 2 03-16-2008 12:59 PM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General Discussion 15 12-02-2007 04:01 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
going from 220 large wire to 220 small? bonedoc Electrical 7 08-06-2007 11:17 PM
