IR Remote Reciever - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 12-06-2011, 09:55 PM   #1
jburd964's Avatar
Rewards Points: 166
IR remote reciever
I'm having trouble reaching my Onkyo Home theater receiver with remote controller from some angles and want to add a external IR reciever onto system. The is reciever is per-wired IR extension. Any input would be greatly appreciated. Eecommindations of model and manufacturer would be appreciated.
jburd964 is offline   Reply With Quote
Old 12-16-2011, 05:40 PM   #2
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
Check out the Harmony line from Logitech. I've got the 890 (a little dated, now) with an FM receiver for it in the media closet. The remote works from anywhere in the house (or even the yard!).
inK
Hammer in Hand, Dad on Speed Dial
http://www.mydadsshoes.com
ink is offline   Reply With Quote
The Following User Says Thank You to ink For This Useful Post:
jburd964 (12-16-2011)
Old 12-19-2011, 02:32 PM   #3
You can also get some IR extenders/repeaters. I don't know if this would work in your situation but I have the Hotlink Pro setup in my basement Home Theater.
You set the eye up in the general area you will be pointing the remote (I mounted mine just above the projector screen (the eye is about the diameter of a pencil so you can barely see it)
You then route it to the where the equipment is. You'll need power to the box as well (Its the small black box just below the top right most speaker jacks)
Run the repeater to the equipment and -using some trial and error - locate the equipments IR receiver
Easy system to setup and it will work with your existing remotes (No need to program a new one). The harmony remote should work pretty well but I just wanted to throw this out there in case you wanted another option or needed something slightly different like I did. I needed complete control from another zone which is where the copper splitter comes in at the top of the box
Exterous is offline   Reply With Quote
Old 12-19-2011, 02:34 PM   #4
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
Hey nice looking setup!
inK
Old 12-19-2011, 05:04 PM   #5
jburd964's Avatar
Rewards Points: 166
Thanks and Nice setup...
Gun control isn't about guns, IT'S ABOUT CONTROL.
Old 12-19-2011, 09:28 PM   #6
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 688
Check Monoprice, thy have a few affordable products that might work for you. http://www.monoprice.com/products/su...&cs_id=1010503
hyunelan2 is offline   Reply With Quote
Old 12-20-2011, 09:26 AM   #7
Hey thanks! I just posted an overview of my build here if you are interested in what the room looks like
$3000 basement home theater build
Wiring a ceiling fan with remote and dual switches Scotter86 Electrical 0 07-12-2011 09:19 PM
Looking for a wiring solution or remote for a Hunter fan/light that works with 2 ciruits Neil McCormick Electrical 2 06-26-2011 02:32 PM
Ceiling fan remote issues Richo Electrical 7 06-06-2011 09:09 PM
Remote with whole house fan? jman1 Electrical 11 05-23-2010 09:07 AM
Problems with Time Warner Cable Remote - DESPERATE meth Home Theater 20 12-03-2009 02:02 PM
