Interference - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-17-2014, 08:03 PM   #1
Rewards Points: 26
Interference
I'm finishing my basement and what to plan for the future including an outdoor patio. I have electrical out there but as I'm unsure when the outdoor will be functional would rather wait to run speaker wire, coaxial network, etc and instead now just add a conduit tubing.
Can I run all of these in the same PVC conduit without interference? Also how close to the electrical wires can I be without sever interference?
kc_fella is offline   Reply With Quote
Old 10-17-2014, 08:45 PM   #2
Rewards Points: 1,476
For speaker wiring, anc Coa, you can use direct burial and skip the conduit. But, it you fell you must use conduit, I would run them in separate conduits, even thought they may coexist in one without issue (conduit IS pretty cheap).
Distance from electrical sould be at least 12", or more if possible. If you must cross electrical, do it at a 90 degree angle.
ktkelly is offline   Reply With Quote
Dimmer switch causing radio interference Bradeno Electrical 15 09-13-2014 12:24 AM
Wiring Interference Question jc1k66 Electrical 11 11-15-2012 08:58 PM
Electrical Interference AT&T U-Verse jamiedolan Electrical 25 03-22-2012 12:17 AM
noise interference pooldaddy9 Electrical 4 08-25-2011 10:09 PM
TV interference when devices are turned on or off in the home - ideas? rightbryce Electrical 7 09-19-2009 11:43 AM
