Originally Posted by Handyman2007
.... My question is are you supposed to cut a hole for the speaker around the boxes and then remove the installed boxes? I would then assume that the speaker grill would cover up the area where the installed electrical box is now located. Any help would be appreciated.
For me, I'm not into perfect sound systems. To this day, I still can't tell the difference between CD sound or sound being played off a VHS tape. Many perfect ears state there's a huge difference. But I can't tell the difference. Especially for background sound.
With this in mind, I'd install flush mount square speakers on their ceiling. As explained above, determine where the other side support boards are and make the needed opening. And if needed, use some 1x4 with PL Premimum (which is construction glue) to install extra support plating. Thus, your flush mount speaker screws can screw into these 1x4 boards (for more solid support). If living space above these speakings, you might want to pack some sound reduction insulation in their upper ceiling areas as well. Thus, reducing some sound travels to upper living space. To me, good quality "surface mount" ceiling speakers are good enough. Connect each speaker to the sound jack that works best for you. For example, if you want voices on the front speakers and other tracks on the ceiling speakers.
If your ears are into near perfect sound, I'd install speakers that can be tilted towards the target person. Or, install pre-tilted speakers. Pointed towards your room's central sofa area. Exspensive (due to their design) but if this is your long term dream home, buying these tilt-able (or pre-tilted design) ceiling mount surface speakers might be worth it.
For others, they may install normal speakers with their own tilt-able support brackets. Thus, allowing more speaker tilting. For some, the little wire that comes out of the speaker box (approx 6" long) is then fed into the little surface place. Drill a hole in the surface plate and use a rubber gromet in the hole. Other designs allow speaker wire to be 100% hidden (like in the below link that shows a single rod support bracket). This hollow rod mounting method works as well.
For visuals, surf the below links:
- Fixed ceiling surface mount:
http://www.cybermarket.co.uk/ishop/923/shopscr6090.html
- Pre-Tilted ceiling surface mount:
http://akamaipix.crutchfield.com/pro...84PPT12-f.jpeg
- Manual Tilt-able surface mount:
http://www.crutchfield.com/S-5KRqPuu...spx?I=121BT34W
Long story short.... Use which method that you feel might work best for your wants.
Hope these ideas help as well...
