Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 05-02-2012, 03:26 AM   #1
Indoor/Outdoor speaker setup
I have a 5.1 channel speaker setup in my living room. Is there a way I can run a switch or something to run some outdoor speakers with the same receiver?
-Ken
kensmash is offline   Reply With Quote
Old 05-02-2012, 10:20 AM   #2
Jack of all - master none
hyunelan2's Avatar
Some receivers have an A/B channel switch for the front mains - check and see if yours does. If so, no extra equipment required.
If not, you'll need a speaker selector. About $15-$20 for a standard one, $50-$75 if you want volume control. They should be available anywhere, but here is monoprice: http://www.monoprice.com/products/su...&cs_id=1090305
hyunelan2 is offline   Reply With Quote
How to setup acoustics for home theater checkjohn Home Theater 5 02-20-2012 09:00 AM
Simplify Sunsmart Setup? Ducati Electrical 5 12-17-2011 09:10 PM
Which generator Interlock setup should I use for my sub panel? homerb Electrical 2 05-10-2010 04:44 PM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
home theater setup cannouu Electrical 5 04-09-2008 07:01 AM
