I'm Converting One Of My Rooms To Media Room - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 04-11-2013, 12:16 PM   #1
Rewards Points: 93
i'm converting one of my rooms to media room
i'm converting one of my rooms to media room. room is located at the 2nd floor. my main problem is room was not pre-wired for anything except cable tv and of course electric socket. i want to minimize if possible not put holes on the walls and ceilings
any ideas, etc.. how to do this.
dumbengineer is offline   Reply With Quote
Old 04-11-2013, 01:54 PM   #2
Pull the carpet back, or look at wires.
toluene_hawk is offline   Reply With Quote
Old 04-11-2013, 10:18 PM   #3
Rewards Points: 216
"media room" means different things to different people. post what you want to do to/in the room and some pics.
Fix'n it is offline   Reply With Quote
Old 04-11-2013, 11:26 PM   #4
Rewards Points: 1,456
Have attic access?
If so, no problem fishing the walls.
1. If not, you can always remove baseboards and replace with baseboard raceway.
2. If not, you can always run wiring behind crown moldings.
3. If not, you can pull back carpet and use flat wire (something like Sewell Ghost).
4. If not, you can remove carpet, open up the sub-floor, install wiring, then replace it all.
Lot's of options....
ktkelly is online now   Reply With Quote
Choosing a Color Scheme For Your Room Micheal11 Interior Decorating 0 08-10-2012 11:03 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 05:47 PM
converting laundry room to bathroom brandisophie Plumbing 8 11-07-2010 02:10 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
