Ideal TV Height? Mounting Above Fireplace - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 05-20-2009, 06:42 AM   #1
Ideal TV height? Mounting above fireplace
I've got plans to re-do my whole fireplace this summer, its covered in wood and I want to do drywall. Anyway, its above my fireplace, which itself is about 8" from the ground, if I were to mount the TV today it would be just above eye level (its 42"), which means if you were sitting on the couch you'd be looking up at it quite a bit. Should I lower my fireplace down to the floor to get the TV lower? What would YOU do?
Also, what are your thoughts on recessing the screen into the wall, or building a mantle out from the wall to hold it, i.e. attached picture. Besides beings more trouble, is it worth it, any disadvantages?
bigburb is offline   Reply With Quote
Old 05-20-2009, 02:02 PM   #2
Ideally, you want your eyes to be somewhere between the middle of the screen and 1/3 of the way from the bottom of the screen. Sitting on a couch, this would put the middle of the screen somewhere around 40-50" off the ground. Of course, the more reclined that you sit, the higher of an angle your eyes will look at the screen, and the higher it can be. Having it mounted above the fireplace is not ideal, but lots of people have it that way. It seems to me that ripping out the stone at the bottom of the fireplace, as well as physically lowering the fireplace is alot of work. If you were not planning on doing it, I wouldn't. If it's coming out anyways, then you may as well lower it. By just stripping off the wood trim, you should still be able to lower it a bit.
As for the picture frame, I wouldn't. Even though it will look nice, it will kill your ability to easily upgrade your TV in a couple of years if you choose to do so. If it is a nice big flat wall, you should be able to fit about 60" up there without it looking out of place (and move the 42" to the bedroom or bathroom or something ).
sgolko is offline   Reply With Quote
Old 05-20-2009, 03:20 PM   #3
yeah we're planning to redo our fireplace anyways, its uuugly right now. I like where you're going with the size factor though, although my wife thinks its big enough already.
Old 05-21-2009, 01:13 PM   #4
Please check my comments about this at New homeowner, 1st "improvement" project
I'm not a big fan due to heat from fireplace possibly affecting the TV and mostly due to the ergonomics.
Lew_B is offline   Reply With Quote
Old 05-21-2009, 03:49 PM   #5
mtbdudex's Avatar
Rewards Points: 12
Out of the box thinking.
Do you really use your fireplace?
If not, just remove the mantle and put the TV in front of the fireplace.
Save the mantle for when you move to make it what it was.
mtbdudex is offline   Reply With Quote
Old 05-21-2009, 03:51 PM   #6
Lots of people have their TV's hung right above their fireplaces, and dont have any issues with it. Just obviously make sure it not too close.
Old 11-14-2013, 10:19 AM   #7
Rewards Points: 1,016
Above a fireplace is typically too high, IMO. Best to be mid to lower of the screen at eye level from viewing position. But many people do it and are satisfied.
____________
Vince
Old 11-14-2013, 12:04 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,980
Well...if you catch me sitting on the couch....I'm not exactly sitting up.
Our TV is also above the fireplace...but I also have it on a bracket that lets me tilt is to that it's at the proper angle.
I personally prefer it up high....that way it's not blocked as easy by people walking by. It also means you can have a couple of chairs in front of the couch and the peoples heads are not blocking the view.....
And if you have kids....it also means you can keep their hands away from it.....
Old 11-14-2013, 12:09 PM   #9
Bill Kearney
Rewards Points: 1,174
NO. Do not put the TV over the fireplace.
It's very uncomfortable to be sitting on a couch that close and having to crane your neck back to see the screen. The only time a set mounted that high has an use is for a large space where you need others across the room to be able to see over the heads of seated people. Like in a bar. Not for typical residential TV watching.
There are strong arguments against having a fireplace anyway. They're basically pointless in modern houses. They end up being just a place that wastes heat. Putting a TV on top of it just makes a bad idea, worse.
wkearney99 is offline   Reply With Quote
Old 11-14-2013, 12:24 PM   #10
JOATMON
ddawg16's Avatar
Hmmm.....wow.....I guess the couch would have to be really close to crane your neck.....
Funny....I sit on my couch and I just have to look up a little....I just use my eyes.....I don't have to 'crane' my neck...
And if I decide to be really lazy and lean my head onto the back of the couch....it means it's a lot easier to see the tv.
I've had both setups.....tv at around 40" off the floor....and currently with it above the fireplace....I'll take the fireplace any day.
Oh....one thing about heat....there is a mantle between the fireplace and TV....most of the heat radiates out.....the tv is not bothered....
Old 11-14-2013, 01:15 PM   #11
Rewards Points: 736
4 year old thread folks.
TheBobmanNH is offline   Reply With Quote
Old 11-14-2013, 01:17 PM   #12
Bill Kearney
True. Yet it's still a bad position for the TV, a warning worth repeating.
Old 11-14-2013, 04:39 PM   #13
JOATMON
ddawg16's Avatar
This is our fireplace.....where the mirror is, we now have a flat panel TV.
We think the height is perfect.
Old 11-14-2013, 07:01 PM   #14
Rewards Points: 1,476
You shouldn't have a TV up there.
Dang, you shouldn't even have a fireplace!
I find this entire thing just laughable.
ktkelly is offline   Reply With Quote
Mounting TV Bracket on Brick Fireplace tanner21 Home Theater 5 05-13-2009 10:59 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 08:17 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
Mounting TV bracket on brick fireplace kashimama Remodeling 4 07-05-2007 10:55 AM
