-   Home Theater (http://www.diychatroom.com/f12/)
-   -   I think I bought a lousy TV (http://www.diychatroom.com/f12/i-think-i-bought-lousy-tv-156871/)
noquacks 09-15-2012 01:25 PM
People,
Had to return the 70" TV cuz sound was defective, so got another one , same type, but without 3D (dont need it). Its a sharp LC-70C6400U. Costco.
Seems the colors/clarity/sharpness is crummy. Picture looks "flat". believe it or not, I had trouble searching the net for reviews/ratings, so thats why I posted here. Maybe yous have some better sourrces, or know why this TV stinks.
I may have to return the monstrosity, based on replies here.
directvman 09-16-2012 11:41 PM
Sharp makes a huge tv cheap but you get what you pay for. You need to make sure you look for resolution first (480, 720, or 1080) for the best picture you want 1080 then look for the refresh rate. I think the sharp tvs only have a 60 MHz refresh rate and the sucks. I'm not really sure about it but I think plasmas get the highest refresh rate (600-800 maybe higher I don't know) I have a LG LCD tv 55" with 250 MHz refresh and it looks pretty good... I see allot of different tvs every day and the sharp tvs just aren't that sharp. Don't get me wrong you get ALLOT of tv for your money but not quality. From what I have seen Vizio probably gives the best picture for the $$$
noquacks 09-19-2012 07:26 PM
Geez, your right, Direct, about vizio being a nicer picture!I have one (in bedroom) and its phenomenal. I think its time to pack up the hunk of junk and take it back. Oh, no way Id get plasmas or LCD's- they generate way too much heat. So, to be sure we're on the same page, are LED's worse because theyre led's? Or is it that its a Sharp LED? Thats the question.
Thanks, Direct!
ktkelly 09-19-2012 08:08 PM
LED flat panels are LCD panels.
The difference is that "standard" LCD's are lit with CCFL backlighting rather than LED's.
Both will generate about the same amount of heat, but the LED panel will use a smidge less electricity.
Sharp is not known for the picture quality until you get to the higher end models, and Costco doesn't have them. But that said, I've seen them look pretty good when fed with a good signal. If you're using a source with a less than 1080P output it's maybe not the Sharp.
Truth be told, you bought the bottom of the line panel (typical for Costco lines). Had this been a LC-70LE732U you would most likely be very satisfied.
My questions are:
What sources are you using?
Connected how?
Vizio, in my professional opinion, is the worst possible TV you can buy quality, and warranty wise. Have a problem and you'll find out why.
Why does Vizio sell so well? It's cheaper than all the rest.
noquacks 09-20-2012 08:02 PM
Thnaks for the info, KT. I will look into this and decide. Sure is worth for one to do research ahead of time. One thing though, on the costco stuff- usually one has to pay 10-30% more for the same item, at least one is ahead there. Im probably gonna return it.
On the heat thing- you dont have me convinced there. LED's, at least all that I have seen/touched and even researched generate way less heat. Its not even close. Maybe we should be talking of BTU's, I dunno.......
Sources?? What does that mean, KT?
but I am studying the owners manual now closer.......
ktkelly 09-20-2012 08:46 PM
Never seen a flourescent that got all that hot either. If the LED is cooler than a flourescent, it's must be dang cold...
Now, if you're talking about a Plasma, I agree, they not only have better picture quality, but they also make great room heaters...:laughing:
Sources?? Im not doing research paper for grad school. Done with that. What sources I read about- cant remember. Don't have to.
Sources: Cable Box, Satellite receiver, Standard DVD, or BluRay DVD.
How connected: Using component video or HDMI?
Lots of variables involved.
ALL cable boxes, and ALL Satellite receivers, output a compressed signal. It is NOT actually 1080P no matter what they tell you (Compare their local HD signals to what you get with an old rooftop antenna. You'll see what I mean).
There's a huge variation with DVD players, including BluRay players.
Some standard DVD's will output 1080i (up converted) while others may be output as low as 480i
Some BluRay DVD's output lower 480i resolutions with component video (unless the BluRay was manufactured prior to Jan 1 2011) unless it's connected via HDMI.
There's always the need to check the output settings on the source equipment, as well as check the settings on the display, and use the best connection possible.
Another good option for these big old hulking monsters is Amazon. Good prices, great service, and good warranty care. Might compare well wih Costco or Sam's club.
Costco member myself...
noquacks 09-20-2012 08:47 PM
OK, specs page does not list the refresh rate. Where else do I go to find it?
ktkelly 09-20-2012 10:04 PM
The refresh rate is 120hz on that set as compared to 240hz on the higher end sets.
BUT....
Don't confuse the refresh rate with picture quality. The refresh rate really only makes a difference in whether, or not, you might see motion artifacts.
The football players look like streaks across the screen? That's typical of a very low refresh rate, and is only seen in the cheapest, and oldest panels.
Honestly, any rate above 60hz to 120hz is fine. My 65" Panasonic Plasma has a refresh rate of 96hz, and I dare say you cannot find a display with a better picture quality.
I suspect that most of your image quality issues may be attributed to what your sources are, and how they're connected.
How did that set look at the warehouse? Good in the warehouse but not so good at home? If so, it's your set up and not the panel...
If it didn't look so good at the warehouse, it's not going to get any better at home...:no:
jimmy21 09-20-2012 10:34 PM
39 Attachment(s)
Are you watching a 1080p bluray hooked uo through hdmi? If not than that is probably the problem. The larger the display, the better the picture has to look. You probably won't noticea difference between 480i and 1080p on a 24" but on a 70" its night and day difference. Same thing with hdmi vs component rca cables
noquacks 09-21-2012 05:01 PM
Hmmm, didnt see picture at Costco- no tV set up (my mistake #1). OK, so we wont worry about refresh rate- soccer players about as fast as football (actually, hand ball)? Soccer games appear very nice. No "ghosts"/whatever.
I have to ask the wife about blueray- I dont use it. Dont even know what it is. May not matter as my complaint is basically with tv cable stations, not dvd's/netflicks, etc etc. Like, FOX news station/History channel, etc. Thats what Im looking at ...
Could I call my cable provider and quiz them on this output signal? How can I ask them to verify it, in case they want to exxaggerate the value?
Thaks!
ktkelly 09-21-2012 08:49 PM
Thaks!
Calling your cable provider will give you a big case of heartburn and nothing more... Definitely won't give you any useful info.
Using Time Warner, Comcast, or whatever cable company as a source, you should have a HD capable box and have it connected via HDMI to the set.
If you don't have the HD tier, then that's what your problem is. The basic service is in standard definition and will look terrible no matter what you do.
That's as good as cable service will get.
You might want to look at DirecTV. Usually that'll get you better quality for less (no I do NOT work for DirecTV).
noquacks 09-22-2012 08:55 AM
Big thanks, KT. You are helping me sort this all out, and get through it. Im gonna verify we have this HD capable box or not.
Missouri Bound 09-23-2012 11:22 PM
I bought a Phillips 55" a year ago in July. I have directv and I do NOT have HD. The picture is scary perfect. I had HD free as a trial and there was no noticable difference. I don't know if this is the case with cable, but the reception with standard definition is close to or near the quality of a dvd. What did make a difference is the cables, HDMI are a must regardless of definition. Mine is also a LED tv. The Phillips is NOT the cheapest flat screen available but as far as I am concerned it is well worth the additional money. I also have a 35" RCA which is LED and it is NOT as clear as the 55". I guess quality is costly.
noquacks 10-07-2012 09:30 AM
Thanks again, guys. Update: I have a cable box that says HDTV CABLE. SCIENTIFIC ATLANTIC, 8300 (HD whatever that means).
Now, coincidentally, recently, the cable company made a change to their program guide background/format. Just a color change in the background of the guide/channel list screen, its blue back with white lettering- just awful (blue is one of the 2 worst colors for the eye). Now, the Vizio in the other room seems beter in that the blue background is a shade darker (easier to distinguish the white lettering), and the huge, new TV in question has the same blue background much lighter! AWFUL! Imagine how easy it is to read white lettering with a very light blue backing!!! (tried playing with contrast/brightness/etc with no change)
So, is this a clue that can be helpful here, guys?
Thanks!
noquacks 10-07-2012 09:42 AM
Found this: (KT recommended this)
http://www.buysquad.com/product.aspx?pf_id=LC70LE732U
Only spec on this model I can find that is better is the Dynamic contrast ratio- 6 million to 1, as opposed to 4 mil to 1 on mine......couldnt find the spec for refresh rate on this higher end one though. pixels is same. aspect ratio same.
