How To Run Speaker Cables Through Walls - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 08-24-2011, 12:26 PM   #1
How to run Speaker cables through Walls
Hello I am trying to run my speaker wire through the walls or ceiling but I have no idea on how to do it. Does anyone have any ideas on how to or videos? It would really help thank you!!
michgav90 is offline   Reply With Quote
Old 08-25-2011, 08:18 AM   #2
Rewards Points: 1,548
First of all, use only speaker wires rated for in-wall use. Romex electrical cable of the desired thickness works fine.
Stringing speaker cable through the wall is no different than strining electrical cable through the wall. It is not necessary to staple the cable to the studs that cannot be seen or reached.
Old 08-25-2011, 02:36 PM   #3
Right but do I drill halls through each stud to run the cable through the wall if I am bring the cable from the front of the room to the bam to connect it to the receiver.
Old 08-28-2011, 09:27 PM   #4
You drill holes in the Stud Bay from either an Attic or Crawl Space. You can mark the proper bay with a piano bit so you know where you're supposed to be drilling.
You will also need a set of glow / fish rods to properly run the wires, especially on an exterior wall with insulation.
RevOzz is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 09:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 12:07 PM
Speaker wire in walls LeviDIY Home Theater 12 11-07-2009 02:56 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
