How To Build A "Bump Out" In Exterior Wall For AV Rack ? With Access Door ? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 07-01-2013, 02:43 AM   #1
How to build a "Bump Out" in exterior wall for AV rack ? with access door ?
I want to install a av rack for theater components in exterior wall so its
flush mounted, not sure if i need to have foundation the size would be roughly...
30 in x 30 in and want a access door to get to the rear ... should i frame and
drywall as normal room ? what bout floor ... desperate and confused ....on my project
denalixxx is offline   Reply With Quote
Old 07-01-2013, 05:47 AM   #2
DIY staff
Rewards Points: 7,174
To get an answer ,a picture of the outside wall and siding will help.
30x30 should not need a foundation--frame the opening just like a door,but with extra king studs.
Old 07-01-2013, 08:10 AM   #3
Rewards Points: 6,652
You did not state if the bump out is going to be into a garage, or the outside wall, that would also mean siding work. Probably would be easier to just use the closet in that room, or make one.
Really need a floorplan of the floor you plan on doing this on.
Old 07-01-2013, 10:24 AM   #4
Bill Kearney
Rewards Points: 1,174
AV gets pretty heavy, I know my AV rack weighs at least 400#. So I'd lean toward there needing to be proper support under it, not just cantilevered out (which would probably require more work to set up properly anyway).
The better question is whether or not that's the best way to approach setting up the gear. There are a lot of better ways to arrange equipment. Cables and extenders can run a good distance. A floorplan or better explanation of what you've got would help.
wkearney99 is offline   Reply With Quote
Door Question: Access Control (Keypad Lock) for Church pbishopp Windows and Doors 3 02-10-2012 03:37 PM
interesting patio door problems....please help. diybrad Building & Construction 6 11-20-2011 11:52 PM
How to build an overhang roof for a entry/patio door Kevin6778 Roofing/Siding 2 08-01-2011 06:15 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Knee wall access door... luner99 General DIY Discussions 2 02-26-2007 12:31 PM
