Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 11-29-2008, 08:08 PM   #1
Home Theater Walls
I have not seen too much on what types of walls are being used for theaters.
i am finishing my basement and i am using beadboard for walls in the rest of the room, but i have a separate area off to the side that i thought about doing osb board covered with a light duty carpet like sub boxes are covered in. I figured the light grey carpet would look pretty cool and help give just a little more ambient light in a mostly dark room (to keep circles off screen from my projector).
Is this a good idea that would be condusive to good sound? I wanted to do the nostalgic dark red movie curtains on teh walls but it would clash bad with my other walls Im a newbie that has done a good amount of research but i couldnt find anythign on this
MAjustin1 is offline   Reply With Quote
Old 12-06-2008, 08:50 PM   #2
motivator
Speedball's Avatar
Home Theater Walls
Almost any type of carpet on the walls will help with sound wave reflections and make a great improvement on the audio side of things.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 12-08-2008, 12:53 AM   #3
Home Theater Walls
Why OSB behind the carpet. I would say minimum use drywall it is allot quieter when it comes to sound rattles and reverberations. Quite rock is even better but pricey. There are also acoustical panels that can be fastened like wall patterns. You could drywall the put up and then fairly large panels like 3 x 6 or so off carpet framed space down the side walls this could give a theater look and balance the sound dampening and still leaving some open surfaces for reflective sound to aid in a full room quality.
Are you worried about the sound carrying to other area of the home. This would call for a double stud wall with insulation between them so no hard surfaces between them touch.
http://www.quietsolution.com/html/theaters.html
Mgmopar
MgMopar is offline   Reply With Quote
Old 12-08-2008, 09:17 AM   #4
Home Theater Walls
I second MgMopar.
Drywall will give a better response than OSB, and quiet rock even more so. You could also look at using resilient channels between the wall and the studs. Just google "resilient channels", you'll even get a link to the quiet rock site.
renfrey is offline   Reply With Quote
Old 12-09-2008, 11:08 PM   #5
Home Theater Walls
I've been working on my project for a few years now. I plan to sheet rock and use sound proof insulation.
IMO, acoustic panels will add lots of $$$. I have 2 other home theater setups in my home. they sound great! What I found is that spending the time with a sound meter balancing, proper speaker placement, good wiring are inexpensive ways to make sure your room sounds pretty good especially if you are going to do a traditional sheet rock room and forgo the room treatments at least initially.
I am no expert but did a lot of research in magazines etc. So far I figure.. to do a perfect accoustical sounding room, I would have to hire a pro. and end up spending more $$.
Patssfan is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Looking for a great guide to settion up my home theater spyguy Home Theater 3 03-25-2011 11:29 PM
A rather HUGE home theater et al TuscolaMatt Home Theater 64 08-03-2010 10:35 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
