Home Theater Size - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 11-23-2009, 05:20 PM   #1
Home theater size
I have a 13x13 space in my attic is it to small for a home theater room?
Kurt1968 is offline   Reply With Quote
Old 11-23-2009, 06:14 PM   #2
The Society of Motion Pictures and Television Engineers (SMPTE) recommends that for the best viewing experience, the idle screen size for home theater use should occupy a 30 degrees field of view in the horizontal plan at the seating position. This implies the ideal TV viewing distance should be such that the screen width occupies an angle of 30 degrees from the viewing position; this corresponds to a viewing distance that is 1.9 times the screen width.
This 30-degree viewing angle has been accepted by many as the standard in home theater design and motion picture viewing.
THX Certification: The THX certification standard specifies a range rather than a single optimum position. THX requires the back row of seats to have at least a 26 degrees viewing angle and while the nearest seating position should correspond to an angle of view that is no more than 36 degrees.
It is believed that within these viewing angle limits, the viewer will enjoy a more immersive viewing experience. These subtended angles correspond to a TV viewing distance that varies between 2.2 and 1.54 times the screen width.
Old 11-23-2009, 06:17 PM   #3
Remodeling Contractor
A theater room should be rectangular not square. An attic is not built to become a room despite what you see and hear on TV. Get a permit for anything you attempt to do at this level.
Old 11-23-2009, 06:49 PM   #4
Is this already insulated & sheet rocked ?
Or something you want to finish off ?
Walk up stairs already in place, windows meet egress code ?
You would need to verify that the joists will support weight
Any size room can be a theatre room, just depends upon what you want
My current TV room is only 13x19, we hardly use the surround sound
Old 11-23-2009, 07:41 PM   #5
It's a walk in attic right off my bedroom. Same level as my bedroom. No stairs. Not finished yet with drywall . It's just storage right now has a window. It has alot of crap in there now don't think the joists would be a problem.
Old 11-23-2009, 08:14 PM   #6
Sounds like it was built as a room - could have been a walk-in closet
With home theatre sometimes less windows is better to control light
And a smaller room can be more easily finished off the way you want
Our TV is "only" 42" - according to that size/distance we should be about 6.6' away from the TV
I know I am further then that
Old 12-03-2009, 02:22 PM   #7
I was reading through the following thread the other day on AVS Forum about smaller home theaters:
http://www.avsforum.com/avs-vb/showthread.php?t=996973
Will give you some ideas about what can be accomplished in a small space!
Caromsoft is offline   Reply With Quote
Old 12-04-2009, 07:36 AM   #8
Thanks dude that sites awesome.
Attic home theater construction Cinema Builder Project Showcase 23 11-19-2009 11:29 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
