Hide Cable/elec Wire Behind Wall For Tv - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 12-24-2013, 01:30 AM   #1
hide cable/elec wire behind wall for tv
What is the best way to hide cable/sound/electrical wires behind drywall of after putting up a wall mount tv?
I'm trying to avoid having to make a new outlet just for the tv where the mount is.
Tiny207 is offline   Reply With Quote
Old 12-24-2013, 02:10 AM   #2
Rewards Points: 14,294
And why would you avoid doing it the right way?
All the cables run behind the wall and ran to a recessed outlet is the best way.
I even open up the wall so I can add the proper blocking in the wall to attach the bracket to.
http://www.homedepot.com/s/recessed+outlet?NCNI-5
Oso954 (04-23-2014)
Old 04-23-2014, 09:09 AM   #3
Rewards Points: 58
just be careful of no horizontal studs.
TheDoc46 is offline   Reply With Quote
Old 04-24-2014, 10:14 AM   #4
Rewards Points: 790
You shouldn't run cables (plug-ins, extension cords, etc.) behind a wall. If you want to run all your sound, receiver, dvr components, you'll need to do it properly by removing the dryway and adding outlets behind or right next to the TVs new location.
Otherwise, you can run them on the outside of wall through channels, hidden in moldings, along shelves, etc.
cibula11 is offline   Reply With Quote
Old 04-24-2014, 12:18 PM   #5
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Electricity aside, there are in-wall rated A/V cables that you can run for your equipment. The difference is the outer-jacket meets fire code.
Search for in-wall HDMI, in-wall speaker cable, in-wall stereo (RCA) cable, etc.
The recessed outlet behind the TV is the best option for electric.
hyunelan2 is offline   Reply With Quote
Old 12-02-2014, 08:27 AM   #6
Rewards Points: 149
I know this a old fourm ,
I'm going thru the same thing and after a lot of searching for info you need to get items that are made for "In-Wall" purpose for Insurances for your house in case of fire or they might not cover damages .
bote110 is offline   Reply With Quote
Subpanel wire through exterior wall Sully313 Electrical 26 05-19-2012 10:17 AM
question on 240 wire size and ground for wall oven twobyfour2 Electrical 8 04-30-2011 07:13 AM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 01:55 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
