Help...Mounting TV On Stucco Wall - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 07-19-2011, 09:17 AM   #1
Help...Mounting TV on Stucco Wall
I am wanting to mount a 27inch TV on stucco wall on our lanai in FL. Are there any stucco anchors or toggle anchor screws that will work? I am having trouble locating the studs from the stucco. I can find them with a stud finder on the other side of wall which is drywall. Do I definitely need to mount it to stud or can I use something just into the stucco???? The mounting bracket only uses two screws to mount. TV is really not that heavy. Thanks in advance for your help!!
dfree75 is offline   Reply With Quote
Old 07-22-2011, 03:52 PM   #2
Do work
Rewards Points: 81
While I never mounted a TV to stucco, I have mounted several TV's. I would say that its probably a good idea to mount into the studs.
What about power and coax for the TV? You still need them so you can cut a hole to mount the box behind the TV. Then with that hole you can measure to find the studs.
liquidvw is offline   Reply With Quote
Old 07-23-2011, 03:19 PM   #3
Rewards Points: 1,440
I would not moiunt it directly only to stucco. It could fall off, taking chunks of stucco with it.
The Following User Says Thank You to AllanJ For This Useful Post:
Dave Sal (10-19-2014)
Old 07-23-2011, 06:47 PM   #4
we used these to anchor handicapped bars in bathrooms with these. they hold a lot.
they come in different sizes also
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Old 07-26-2011, 11:48 AM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Most modern 24" LCDs weigh less than 20 lbs. I think you'd be fine with 2 toggles.
Get the biggest ones your bracket will accept.
A single 1/8" toggle will hold 25 lbs in 3/8" drywall. The stucco and wire mesh behind it has to be stronger than 3/8" drywall
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-28-2011, 11:24 AM   #6
Rewards Points: 518
I just mounted a 32" into drywall that did not have a usable stud. I used three of these:
I purchased ones that are rated to 200lbs a piece. The only thing you have to watch is that even though combined these anchors could support 600lbs, can the drywall? If it's fairly light you'll be fine. These anchors are tough.
n0c7 is offline   Reply With Quote
Old 07-29-2011, 08:54 AM   #7
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
When it says 200 lbs thats an ultimate load ( probably rated in 1/2" drywall) You usually want to apply a safety factor of 4, so that means that on your 1/4" molly bolt your ALLOWABLE load is 50lbs each. When ever you are deciding on an anchor, always make sure you understand if the load rating is an Ultimate Load, or an Allowable (aka: Working Load). When in doubt, assume it's an ultimate and apply a safety factor of your own based on what it is your anchoring
When your base material is drywall, you'll find that most similiar sized anchors have similiar load ratings, because the drywall is going to be the weak link
Old 07-29-2011, 09:31 AM   #8
kwikfishron's Avatar
Rewards Points: 172
Do you have a electrical outlet on that wall? If so there should be a stud just to the left of it, you can check by pulling the plate off.
If you can find one stud you then can pull layout (16" or 24”) off of that to find studs in the area where you want to mount the TV.
Even if there’s no outlet on the outside wall and there is on the inside of the same wall you can do the same thing to figure out where the studs are.
kwikfishron is online now   Reply With Quote
Old 10-07-2014, 03:26 PM   #9
Rewards Points: 80
how did it go? Post some pictures. I'm about to do this project at my home.
Koolhaas is offline   Reply With Quote
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Flashing question where eavestrough meets stucco wall? chadurban Roofing/Siding 3 12-31-2010 06:42 PM
Mounting Landscaping Lights to Stucco Jawbreaker General DIY Discussions 1 09-21-2010 06:51 AM
Mounting a TV "IN" a wall dchutnik Home Theater 3 01-25-2007 10:05 PM
