Help Me Pick Out Components For My HT Setup - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 05-09-2009, 11:31 AM   #1
Question
Help me pick out components for my HT setup
Hello all, I finally have time and decided that I want some sort of home theater. What I am looking for is more important than the 'best ht experience'. It is more of a game room than a home theater.
I'm getting two 42" 1080p HDTVs and I want to have the same image on both. I have a pair of KRK ST6 passive monitors http://pro-audio.musiciansfriend.com...ach?sku=602270 and I want to buy one of their sub woofers also.
I do not care about surround at the moment and I am happy with the flat and natural response of these monitors.
I need help, however, in order to determine what other components I will need to acquire.
I have:
2 Sharp HDTVs
2 passive 6" monitor speakers (100 W)
1 sub
1 Blue-ray player
1 Satellite TV receiver
I want:
To be able to see either the satellite tv or blue-ray on both TVs at the same time and also is there an amplifier or receiver that will allow me in the future to hook up another 2 speakers to put elsewhere that will output the same sound?
The less components I have to buy, the better.
Also what cables or attachments will I need?
I tried looking online at some components but have some trouble regarding the different inputs and outputs of each one!
ogarza is offline   Reply With Quote
Old 05-12-2009, 06:49 AM   #2
Rewards Points: 1,492
To have the same DVD player or satellite/cable box feed HDTV video to two TV sets you need one of:
1. A powered HDMI splitter, namely a device with one HDMI input passing through to two HDMI outputs. This is a piece of electronics, not a Y-connector or switch box.
or,
2. One of the TV set's having a video out jack, must be of the HDMI variety to get HDTV quality to the other TV. The purpose of a video out jack on a TV set is the purpose you intend, to daisy chain the same program to another TV set.
Some A/V receivers may have #1 built into them, namely have two HDMI outputs to connect to TV sets. You may also be able to connect the HDMI output of a satellite box to one TV set and the S-video or component video output to another TV set. Except that (yellow) composite video and S-video are always standard definition and component video may be either high definition or standard definition depending on the copy protection on the disk or broadcast.
Some A/V receivers have A/B speaker selectors to allow you to have two sets of speakers. You want to be sure the receiver can play both sets at the same time. Most require that the speakers each have an impedance twice that of the amplifier rating in order for you to use the "both A and B" setting. (for example 8 ohm speakers with a 4 ohm receiver amp. output)
An alternate arrangement that is more foolproof in terms of not overloading the receiver amplifiers is a jury-rig. Both the theater room and remote speakers for each applicable channel are wired in series (different kind of daisy chain with only one wire per terminal, positive of one speaker to negative of the other speaker and no Y-connections or T connections). To turn off the remote speakers you have manual switches that short circuit them leaving the theater room speakers operating by themselves. Here each speaker need have an impedance merely equal to or greater than the amplifier output impedance. With just two remote speakers (right front and left front) this jury-rig is not terribly complex.
For speakers, any cable of the same gauge, including romex, works just as well as monster cable although nicer looking cable will cost you more.
Old 05-12-2009, 08:50 PM   #3
AllanJ -- Great info. Never thought about daisy chaining them together.
ogarza -- Why do you want the same signal on both? For 2 players during games? Sorry if that's a stupid question.
PunkyPoo is offline   Reply With Quote
Old 05-21-2009, 12:08 PM   #4
not at all punkypoo,
the reason for this is that the room has a door to an outside area and i want to be able to walk outside and not miss the show
Old 05-25-2009, 11:04 AM   #5
Just to add a bit, an AVR with 2 HDMI outs will run you quite a bit (they start at about 1800 i think), but be more than enough to add more speakers on either the same zone or another zone later on, and power them all.
I think your best option would be to get an HDMI splitter, such as this one:
http://www.monoprice.com/products/pr...seq=1&format=2
sgolko is offline   Reply With Quote
Old 06-16-2009, 10:39 AM   #6
Best home theater receiver for wife
Hi,
Can anybody recommend a good home theater receiver that is Wife friendly? Ie, my wife just needs to be able to push buttons that say "TV" or "DVD" and have it work.
Basically I'm looking for something like the Denon AVR-4306 except with HDMI 1.3, and a simpler remote or front panel. I need a multizone system that's Blu Ray friendly and has ethernet hook up and Ipod/Usb connections, but I'll sacrifice whatever I have to to get something simple.
Sorry if this isn't the best thread for this question...any suggestions welcome.
Eric
KeepBrideHappy is offline   Reply With Quote
Old 07-26-2009, 05:35 PM   #7
MT Stringer's Avatar
Rewards Points: 240
@ Orgarza, I have a Yamaha RX v-663 AV receiver. I think it will take care of all your needs. It has two HDMI inputs and one HDMI output.
I have the Comcast cable box connected to it. Also a Sony BluRay player, and a Toshiba DVD/VHS combo. A single HDMI cable goes from the receiver to the 46 inch Samsung LCD tv.
So, I can watch cable programs or play the blu ray or play a vhs tape or listen to the radio. I also put in a 5 speaker system. Since this is in our living room/den or whatever you call it, we usually don't turn up the volume but the sound is still good.
I also bought a Logitec Harmony One remote to control all of the devices.
EDIT: I agree with the suggestion to get a splitter. Then you simply run the HDMI cable to the second tv.
I've bought a considerable amount of stuff from monoprice. Great prices on a lot of their stuff. Remember you need the "In-Wall" cables if you are routing your cables through the walls.
Hope this info is helpful.
Mike
MT Stringer is offline   Reply With Quote
Tags
dual display , home theater , monitors
New House Structured Wiring Setup for CATV gregsenne Electrical 13 02-19-2009 08:00 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
Keeping AV components cool rhino7448 Home Theater 5 09-16-2008 06:57 PM
Hissing components?! Speakersrock Electrical 2 06-13-2008 11:46 PM
home theater setup cannouu Electrical 5 04-09-2008 06:01 AM
