Help With Coax PROBLEM - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 01-25-2009, 04:41 PM   #1
Handyman/ Snow Removal
Help with coax PROBLEM
Hey guys,
I've got a coax cable coming into a room going to a two way splitter. Off the splitter comes the internet and phone. I need to have 2 cables coming out of there as well. I've tried the 4 way amplifier splitter, the internet and phone wouldn't work. I tried a non amplifying splitter, cable, and the internet works, just not the phone.
Any ideas?
McGaw is offline   Reply With Quote
Old 01-25-2009, 06:18 PM   #2
Originally Posted by McGaw View Post
Hey guys,
Any ideas?
Amps dont play well with devices that send data.
What are the new 2 coaxes going to be used for?
What cables do you have? rg/59, rg/6?
Would it be easy to run new coax?
rgsgww is offline   Reply With Quote
Old 01-25-2009, 06:20 PM   #3
Home Theater Guy
Is there a splitter before the feed to the room? You may not have enought signal. Try the following, a 2-way splitter into 2 2-way splitters. Internet and phone on one, your other feeds on the other.
Greg C is offline   Reply With Quote
Old 01-25-2009, 09:12 PM   #4
The two new coax cables will be for cable
Old 01-26-2009, 05:57 AM   #5
Safe, Most of the Time!!
brokenknee's Avatar
What is the difference between rg/59 and rg/6? Is one preferred over the other?
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 01-26-2009, 07:05 AM   #6
Is there a splitter before this room? You may get grainy tv signal, or may not.
Try this, 3-way, 3.5 db port to a 2-way for internet and phone, other 2 for tv.
Old 01-26-2009, 07:11 AM   #7
The attenuation and capacity
http://www.marine-electronics.net/te...t_features.htm
Notice how satellite signals don't work well on rg/59.
Rg/6 has an 18awg center wire. Rg/59 has a 22 awg, rg/11 has a 14 awg center wire. Most coax has a steel, copper coated wire instead of all copper, since all copper doesn't make a big difference with normal use.
Last edited by rgsgww; 01-26-2009 at 01:46 PM. Reason: Steel part...it didn't make sense.
Old 01-26-2009, 11:46 AM   #8
Home Theater Guy
RG-59 is 20 awg. Solid copper is recomended for satellite use, and if you are using it for a audio/video signal instead of RF.
Old 01-26-2009, 12:42 PM   #9
RG/59 could be either 20,21,22, or 23 AWG. The RG numbers do not have physical specifications associated with them.
jerryh3 is offline   Reply With Quote
Old 01-26-2009, 01:48 PM   #10
Quad shield is another story. I use it since my old work runs are near AC.
Rg/6 works just fine.
I would ditch rg/59 altogether...
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
