-   Home Theater (http://www.diychatroom.com/f12/)
-   -   Help with coax PROBLEM (http://www.diychatroom.com/f12/help-coax-problem-36816/)
McGaw 01-25-2009 04:41 PM
Hey guys,
I've got a coax cable coming into a room going to a two way splitter. Off the splitter comes the internet and phone. I need to have 2 cables coming out of there as well. I've tried the 4 way amplifier splitter, the internet and phone wouldn't work. I tried a non amplifying splitter, cable, and the internet works, just not the phone.
Any ideas?
rgsgww 01-25-2009 06:18 PM
Originally Posted by McGaw (Post 219044)
Hey guys,
Any ideas?
Amps dont play well with devices that send data.
What are the new 2 coaxes going to be used for?
What cables do you have? rg/59, rg/6?
Would it be easy to run new coax?
Greg C 01-25-2009 06:20 PM
Is there a splitter before the feed to the room? You may not have enought signal. Try the following, a 2-way splitter into 2 2-way splitters. Internet and phone on one, your other feeds on the other.
McGaw 01-25-2009 09:12 PM
The two new coax cables will be for cable
brokenknee 01-26-2009 05:57 AM
What is the difference between rg/59 and rg/6? Is one preferred over the other?
rgsgww 01-26-2009 07:05 AM
Is there a splitter before this room? You may get grainy tv signal, or may not.
Try this, 3-way, 3.5 db port to a 2-way for internet and phone, other 2 for tv.
rgsgww 01-26-2009 07:11 AM
The attenuation and capacity
http://www.marine-electronics.net/te...t_features.htm
Notice how satellite signals don't work well on rg/59.
Rg/6 has an 18awg center wire. Rg/59 has a 22 awg, rg/11 has a 14 awg center wire. Most coax has a steel, copper coated wire instead of all copper, since all copper doesn't make a big difference with normal use.
Greg C 01-26-2009 11:46 AM
RG-59 is 20 awg. Solid copper is recomended for satellite use, and if you are using it for a audio/video signal instead of RF.
jerryh3 01-26-2009 12:42 PM
RG/59 could be either 20,21,22, or 23 AWG. The RG numbers do not have physical specifications associated with them.
rgsgww 01-26-2009 01:48 PM
Quad shield is another story. I use it since my old work runs are near AC.
Rg/6 works just fine.
I would ditch rg/59 altogether...
