Hello...I Need Wiring Advice - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 02-13-2008, 03:11 PM   #1
Hello...I need wiring advice
I'm in the pre-drywall wiring stage on our home and I'm pre-wiring for whole house audio, surround sound, and structured wiring. I've run into a bit of a problem...the only place that I can put all my audio/video equipment someday happens to be right below my main run of electrical wire. We're talking the "main artery" of my entire electrical system where almost all my home-runs to my electrical box occur.
My question is should I completely avoid that area entirely to avoid sound interference (which wouldn't be ideal for cost and practicality), or does the same rule apply with BUNDLES of AC as it does with a single AC wire (meaning that I stay at least 12 inches away from the AC cable with my speaker wire, or cross it only at 90 degrees)?
Does this only apply to speaker wire? Can I run all my cat5e and RG6 cable alongside the AC without any trouble?
Thank you in advance for any help and suggestions!
bradeja is offline   Reply With Quote
Old 02-13-2008, 03:41 PM   #2
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
I have installed a few Leviton Integrated Network Systems and they claim that you cannot be within like 3' of the main service with your disribution box. They will not warantee their equipment if you are closer than that. However, I have had to install them closer than that from time to time and haven't noticed a huge difference. Chances are, whatever system you are putting in isn't a high enough quality to stand much to loose. I don't mean disrespect by that comment but you would have to go top notch will ALL the components, speakers, tv, cable, disribution box, connectors...). My only advice to you is that if you are concerned about it, don't do it. If you ever get a glitch in audio/visual quality, you will blame it on the placement of you panel.
jcalvin is offline   Reply With Quote
Old 02-13-2008, 04:14 PM   #3
Well, actually, my integrated network box is a good distance from all the electric cable. My concern is more with the speaker wire, since I've heard that running it close to electrical wires is a no-no. I can run them perpendicular to the wires, but I wondered if the BUNDLE of wires would generate even more interference.
You might be right, though. If I have any doubts, I should find another route (for the speaker wire, at least). Thanks for your feedback.
Old 02-13-2008, 04:22 PM   #4
Electrician
Good luck wiring a house and not running near any electrical wires, honestly I work with LV guys alot and they run their homeruns in the same bay as my wires... dont think its a problem... you are using cable suitable for in wall use correct?
chris75 is offline   Reply With Quote
Old 02-13-2008, 09:32 PM   #5
yes, all my wire is rated for in wall, UL listed, and my speaker wire is IC3 rated.
Old 02-13-2008, 09:48 PM   #6
Electrician
I would not worry too much about the higher voltage wires then, your wire is probably twisted to eliminate any unwanted noise...
Old 02-14-2008, 03:58 PM   #7
If you are worried at all and don't want to take a chance with the speakers humming then get some shielded speaker wire. Here you can choose what's best for you Shielded speaker wire
Check what amp the speakers are and how big. I have one set that has 6" woofers and My receiver pushes 110 watts and they are on 16 gauge and then I have a pair of 15" Cerwin Vegas that I have run 12 gauge for.
I just want the best sound and want to make sure the wire is big enough, running to small a gauge wire is no good either. Same with car stereos don't play around with small wire, do it right so if you get bigger speakers in the future you are covered.
kjwoodworking is offline   Reply With Quote
Old 02-14-2008, 04:20 PM   #8
So 16 gauge wire should be big enough for whole house audio (all runs will be 50 ft or less)?
Old 02-14-2008, 04:24 PM   #9
Electrician
16 and 14 are pretty normal to see installed...#12 for longer runs..
12 volt marine wiring - can anyone help? arichard21 Electrical 6 11-29-2007 05:47 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 08:18 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
