#1 |
HDMI Wiring Advice - In-Wall or Outside?
I need to figure out the best way to get HDMI cables from my Cable Box and Audio Receiver to our Flat Screen TV, which is over a gas fireplace. I was thinking about how to get the wires through the wall and into the basement, which I've already done for speaker wire for the Receiver, but doing this for the Flat Screen is a little more complicated ... due to the Gas Fireplace. Then I thought that I might be better off going outside with the wires, in such a way as that I could hide them behind the Vinyl Siding, and then into the basement? They say a picture is worth a thousand words, so what do you think?
#2 |
Going outside with the wire seems like it would be much easier and would be a lot less work, but is there a downside? How weather resistant is HDMI Wire or do they have special HDMI Wire for going outside? How would I do this if I really wanted to do it "the right way"? This is what is looks like from outside ...
#3 |
Average Joe/ex-Navy IC3
Proper way is to cut the drywall, so that you can pull all of the wires, then connect into a wall plate.
#4 | |
HDMI Wiring Advice - In-Wall or Outside?Quote:
Thanks again - Best regards, John |
#5 |
No, because they are not made to be used outside.
#6 |
Yeah, that's what I was afraid of ... could always go this route:
http://www.outdoortvspot.com/departments_name_Outdoor-TV-Cables_path_11410.html And ... for the price of those outdoor cables (50' for $175.00 ), I think I'll figure out how to run the cables down into the basement through the wall. Had a real tough time with the one I already did for the receiver ... routing lines outside ...![]() Thanks much for sharing your knowledge! Best regards, John |
#7 |
Thought I would mention Wireless HDMI. Something to look into at least. When I ran mine I had now idea wireless existed.
#8 |
HDMI Wiring Advice - In-Wall or Outside? |
#9 |
#10 |
I have almost the exact same setup. I have a TV above my gas fireplace and I want to hook up my boxes/audio receiver in the corner of the room.
The goal is to keep all boxes organized in the corner, run HDMI up to the TV through the wall, and wire the room for surround sound from the audio receiver in the corner. I have a crawlspace (instead of a basement) under the room, and it is easy access. My main concern is to run cables through the wall with the tv/fireplace, I'll have to deal with insulation. Also, will I even be able to get a cable up around the fireplace and out into the nook? I have never done this type of thing before either, so I don't want to run into any issues mid-project. Any advice? Sherm - did you decide on how you were going to do it? If so, how is it working out? |
#11 |
Easy way to do it is, Cut the drywall to install a conduit to be able to pull the wiring back up point to point. Even better way is to just forgo the install above the fireplace, and locate somewhere else in the room such as a cabinet that you can raise the Flatscreen out of if you want it out of sight when not in use, and equipment in a closet that has cooling for keeping the audio and video equipment cool.
Placing it above the fireplace just screams look at me, especially when the set is off. Look at some of the set ups in http://www.soundandvisionmag.com/cat.../installations and some of the other trade sites & magazines. |
#12 |
Sherm - have you done your wiring yet?
#13 |
Being as HDMI is a fully digital format, I would expect that the image "quality" would be exactly the same. It will work, or it won't. There could be a marginal area where the signal could break up occasionally due to interference, but I don't call that a "quality" problem.
#14 |
Wireless HDMI does work, but the setup to do so is rather pricey. If you want to go outside I would recommend doing HDMI over Cat 5. This gives you two components to connect HDMI on to from either end and allows the distance between to be run in data cable, (which is pretty inexpensive in bulk and can be run outdoors). HDMI cables can also be had very inexpensively up to 25 ft with no repeater to cover any extra distance.
HDMI cables here: www.av-express.com HDMI extenders here: www.gefen.com Last edited by stvmcq; 04-20-2011 at 11:57 AM. |
| Display Modes | |
| How to rough wiring in this wall | WillK | Electrical | 13 | 07-17-2012 08:07 PM |
| Seeking advice for wiring in hot-tub. | YerDugliness | Electrical | 47 | 03-18-2012 12:35 AM |
| Load Bearing (point Load) Wall Removal Advice | Stringer9 | Building & Construction | 5 | 11-09-2010 11:14 AM |
| Faux stone exterior wall by pool - advice please! | t3w | Building & Construction | 5 | 03-02-2010 09:54 AM |
| bathroom wall advice | bigbrad123 | General Discussion | 9 | 06-07-2006 08:26 AM |
