-   Home Theater (http://www.diychatroom.com/f12/)
-   -   FM Broadcasting around house (http://www.diychatroom.com/f12/fm-broadcasting-around-house-105337/)
seansy59 05-23-2011 01:42 PM
14 Attachment(s)
FM Broadcasting around house. I am an audio wizard, repair person, collector, etc. Check my youtube channel out for more if you really want. http://www.youtube.com/user/seansy59?feature=mhee
I have many receivers, and radios around the house, outside, outbuildings, and I am on a 2 acre area of land that I need music to broadcast to. I am in a very wooded area. I was looking on ebay at broadcast transmitters that are o.k music quality. Nothing Hi-Fi, just something to broadcast in stereo that sounds decent. This 0.5 watt transmitter looks good, and got a 4 or 5 star rating on Amazon.com. I would use the antenna that's included.
http://cgi.ebay.com/0-5w-Fm-transmit...item4aa98e7075
Anybody else think this is good for 2 acres of broadcast (maybe a little farther). I would like to plug this into my laptop, iPod, cd player, etc. and broadcast it to many (wireless) locations around the house and outside. I also would use it to broadcast for seasonal uses (Halloween & Christmas uses) that I use for music in needed areas for a seasonal "walk" I arrange. My budget is MAX $100 including shipping.
Anyone want to help me with this? Is it a good item, bad? Trouble I would run into? Any help is appreciated :)
tonystewart1 05-23-2011 09:09 PM
I dont know if you can broadcast an FM signal stong enough to cover 2 acres legally. First I would contact the FCC to see where you stand legally before I spent any money.
Check out this link it says the farthest you can broadcast a FM signal is 200 feet.
http://www.fcc.gov/guides/low-power-...ons#UNLICENSED
hyunelan2 05-23-2011 09:17 PM
FWIW, I have a small USB powered transmitter that hooks up to my computer. I think it was like $30ish on eBay. If I tune it in on my truck, I can get about 2 houses down before it disappears - probably about 300'. I know I can cover my whole yard without issue, but I only have a 1/2 acre.
seansy59 05-24-2011 04:58 AM
14 Attachment(s)
Im not too worried about the FCC over here. I am in such a wooded and "dead zone" area, that my so called 20 mile walkie talkies won't even go down the road. I don't think it would be a problem with a small transmitter and mini antenna sitting in a room.
tonystewart1 05-24-2011 01:59 PM
You might still should worry about the FCC. They do flyovers every year to detect signal leakage if they detect a FM signal with to much power they will be knocking on your door. A neighbor of mine had the FCC show up at his door with a search warrent because he modified his CB to put out more power. He has no CB equipment and thousands of dollars in fines.
The FCC are worse than the CIA.
Leah Frances 05-24-2011 04:54 PM
Why not transmit WiFi? You won't run into the same FCC problems. I would not dismiss them as no problem unless you talk to them. Seems like a good time for an 'anonymous' phone call from a pay phone (if you can find one) to find out what your limits are.
Trust us, the FCC wants to answer your questions and help. They are not the devil.
seansy59 05-24-2011 07:34 PM
14 Attachment(s)
The only problem is, wi-fi won't transmit to the 80's analog receivers I have:) I'm hoping the transmitter wouldn't cause a problem. I haven't bought it yet, I'm still deciding. I really don't see a problem as long as the signal never leaves my property nor disrupts the neighbors. I know the transmitter has power adjustment, as I read on another website. It can adjust from 0.5 watts to 0.1 watt. I can't believe the FCC would be that strict if it doesn't even bother anyone, or even leave the somewhat "perimeter" of the property.:laughing:
