Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 06-14-2010, 09:10 AM   #1
Flat screen TV screws?
Sorry if this is the wrong area. I have a wall mount but it appears to use 5/16" head less screws. I cannot seem to find them at Lowes. It also could be metric. Does anyone know what they are? It seems like most flat screen TVs have screw holes on the back for them. Thanks.
Frank Lardino
FrankL is offline   Reply With Quote
Old 06-14-2010, 09:40 AM   #2
nap
You talking to me?
nap's Avatar
well, not really sure what a headless screw is. If you remove the head of a screw, it is a stud and you use nuts to clamp something together. If there are means to drive the screw such as an internal hex, it is a set screw or simply, a screw with an internal hex drive.
can you describe what you are looking for a bit better?
are all the threads of the same type and pitch? what does it screw into and what is attached to what using these screws?
Old 06-14-2010, 09:48 AM   #3
It was a dark and stormy
Yoyizit's Avatar
http://www.fastenal.com/web/products...1125439&ucst=t
Old 06-14-2010, 03:11 PM   #4
Surprised your wall mount didn't come with the screws you need. Mine came with a massive pouch with every possible fastener to match whatever brand TV you are hanging. I used four, and I still have about 200 others, you know, in case I buy another, bigger TV.
gdoucette is offline   Reply With Quote
Flat screen tv causes gfi to trip SS396 Electrical 2 11-23-2009 02:34 PM
flat screen outside? tripflex General Discussion 16 09-22-2009 05:06 PM
Glass mirror over fireplace, any ideas how to install flat screen TV? dynamo Building & Construction 1 07-25-2009 10:02 AM
Uneven Studs and mounting a Flat Screen -Please Help! SassyLilRedhead Home Theater 6 01-22-2009 10:33 PM
New to the site - Need help installing a 46" Flat Screen above Fireplace shawna Home Theater 2 11-26-2008 04:25 PM
