Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 12-21-2008, 04:33 PM   #1
fios connection
my toshiba flat screen is lacking a hdmi outlet. the fios dvr came with the hdmi for easy hook-up.is their an alternative using coaxial?
justorr is offline   Reply With Quote
Old 12-21-2008, 05:23 PM   #2
fios connection
Component? S-Video? Composite? Dvi? What model is the TV?
jerryh3 is offline   Reply With Quote
Old 12-21-2008, 06:45 PM   #3
fios connection
There should be several alternative connection methods in the DVR manual.
Old 12-24-2008, 05:18 PM   #4
fios connection
Your tv most likely has component, red blue and green.
What ports does your tv have?
s-video will not give you hd, composite will not give you hd, coaxial does in some situations, but may not in this.
Dvi will give you hd.
And vga will give you hd.
rgsgww is offline   Reply With Quote
Old 12-29-2008, 12:05 PM   #5
fios connection
and component will give you HD. (red/blue/green)
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-01-2009, 04:24 PM   #6
Home improvement newbie
fios connection
I have FIOS as well, you can use component cables and still get HD if your TV does not have HDMI. If you don't have either, it's time to upgrade the TV
callmedpit is offline   Reply With Quote
Wall heater connection to breaker mw6263 Electrical 2 06-22-2008 11:47 AM
frozen gas line connection fisherziggy Plumbing 4 01-06-2008 03:37 PM
sub panel connection rtyui2 Electrical 6 11-28-2007 05:24 PM
Post to Piling connection george514 Building & Construction 4 06-07-2007 11:23 AM
Bathtub drain and w&O overflow connection Manuel6 Plumbing 5 11-03-2006 12:23 PM
