Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 08-27-2011, 11:27 PM   #1
error code 22 on mitsubishi big screen ws-55511
I replaced the stk 393-110 IC chip and the tv worked perfect for a day and a half... then... it shut off and would not come on. This is when I started getting the error code 22. I then replace the two 5 amp pico fuses f9a04 and f9a05 and it didn't fix the problem. I have since read that I should have replaced the power caps but am also reading that a closer match to my problem is the IC chip agaim. I used a generic chip and did not insist on the "sanyo" chip. Is there and educated opinion out there as to whether the cheaper chip is my problem or should I look elsewhere? Any appropriate help would be aprreciated. Thanks!!!
jonesy is offline   Reply With Quote
Old 09-05-2011, 03:39 AM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
First, this forum is not a techy forum like over at AVSforum.com. As for your problem, did a search and this is what I found.
http://search.yahoo.com/search;_ylt=...&cop=&ei=UTF-8
Personally, because it is a Rear Projection, and it is not even cost effective to repair due to Plasmas & LCD sets have come down so far in price. You can get a very good 51 or 60 inch Plasma for under $3,000.00, unless you want a very good top of the line, studio quality 60", then you are talking about $6,000.00
Tags
error code 22, mitsubishi ws-55511, technical repair
In-swing non-crank casement window screen blee Windows and Doors 2 05-21-2011 03:42 PM
Screen and Recoat correct way to go? pktrocket85 Flooring 4 03-19-2011 02:49 PM
Shower Screen tomperkins Plumbing 4 12-05-2010 08:22 PM
Tiling a patio that already has screen enclosure. gggonzalez Flooring 2 05-02-2010 11:25 AM
Compaq Presario issues (1) chugging and (2) Compaq Organizer screen proofer PC Repairs & Upgrades 12 09-21-2008 10:36 AM
