Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 03-25-2009, 09:44 PM   #1
electrical outlet question
hey i have mounted a 32 inch lcd on the wall in my room and i want to clean up the cords i have run low voltage cords behind a wall before but i would like to also run the power through the wall .... i gather i can not just run the power cable through the wall what are my options the power outlet is about 2 feet below the center of the television .... thanks in advance
hawesg is offline   Reply With Quote
Old 03-25-2009, 10:03 PM   #2
Xtreme DIY'r
No you can't run power cords thru the wall
You can tap off the outlet & add an outlet behind the TV
Or get some wire mold to hide the wires
Old 05-20-2009, 02:00 PM   #3
Another option is a product called PowerBridge.
http://www.powerbridgesolution.com/
It was basically designed for exactly what you are looking to do.
Steve
sgolko is offline   Reply With Quote
Home Electrical / Car Stereo Question pjpjpjpj Electrical 4 08-12-2012 07:59 PM
Bulhead Conceiled Electrical Outlet rayignacio Electrical 5 02-08-2009 03:52 PM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 11:30 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 04:31 PM
Question on GFI outlet HDoc Electrical 3 09-18-2006 10:38 PM
