Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 02-06-2011, 09:46 AM   #1
DVD player that supports USB
Bought this a while back
http://www.ncix.cn/products/index.ph...oduct_id=41917
I have a 2G flashdrive that I formatted in FAT32. I copied an avi file to it and the player played it with no issues. I also have a 120G IDE desktop drive that was formatted with NTFS (FAT32 max is only 2G) I copied the same avi file to it and the player would not play it.
I also formatted the 2G flashdrive to NTFS and it would see the drive but wouldn't see the avi file.
So just a warning, if you were hoping to hook up a large drive to this type of DVD player, make sure you test it out.
Or maybe I am doing something wrong.
fjacky is offline   Reply With Quote
Old 02-06-2011, 03:53 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Confused as to what your problem is.
Old 02-07-2011, 03:36 PM   #3
Mad Scientist
Most devices won't understand an NTFS filesystem.
FAT32 should actually support drives up to almost 4 TB though, with the limitation that any one file can't be larger than 4GB. Have you tried formatting the 120GB drive with FAT32?
McSteve is offline   Reply With Quote
removing roof supports in attic, installing a room denemante Building & Construction 4 01-24-2011 09:51 PM
Advice on replacing porch supports trobinson017 Building & Construction 7 05-14-2008 07:01 PM
question about 220V cd player vs 120V sdipiet@msn.com Electrical 2 11-25-2007 04:23 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
45 Degree balcony supports rickr01 Building & Construction 5 09-12-2005 12:10 PM
