Disconnected Cable TV / Search For Local Channels ?? - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 08-18-2015, 04:12 PM   #1
NorPlan's Avatar
Rewards Points: 224
Not the least bit Tech Savy , Curious if I can Find a Local TV Channel without raising an Antenna ?? We dropped the Cable TV via Satellite a few months back.. We still have the Apple TV & Netflix hooked up.. The Home Phone & Internet are accessed via WiFi.. My Question , is there a Setting I can click onto to bring up a local TV Channel without having to Install an Antenna ?? The nearest Transmission Tower is approximately 3km's away as the Crow Flies ' were surrounded by Bush (Rural).. Cheers , Thanks
NorPlan is offline   Reply With Quote
Old 08-18-2015, 09:37 PM   #2
GrayHair's Avatar
Rewards Points: 964
I doubt it. TV antennas are designed to be efficient in TV frequency bands and inefficient outside TV bands. Combined with an impedance matched transmission line (coaxial cable), they provide the path to get the signal to your TV.
You can go to TV Fool, enter your address and get a report of what channels you might receive.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
The Following User Says Thank You to GrayHair For This Useful Post:
Dave Sal (08-23-2015)
Old 08-19-2015, 07:10 AM   #3
Rewards Points: 2,634
You will need an antenna, but you don't need to put up a tower or mount it to your chimney. Google "rabbit ears antenna". Sure, you will get better reception with an antenna on a 30 foot tower, but the indoor rabbit ears will work fine if you have nearby transmitters.
SPS-1 is offline   Reply With Quote
Old 08-19-2015, 07:12 AM   #4
Rewards Points: 3,783
It depends on whether the locals in your area are using the VFH or UFH band.
The first step is to tell you TV to search for broadcast channels. This is done in you TV menu. There is no such thing as an HD antenna. An antenna is an antenna. A pair of rabbit ears, an old UHF indoor antenna or even a metal coat hanger bent into a 12" circle combined with a coax converter (300 OHM to 75Ohm) and a short length of coax may be all you need.
The converter is required because modern TVs only have coax inputs.
I have a homemade antenna in the upstairs of my house that pulls 18 stations with a better signal quality than we can get from the cable company. Not bad for something made from scrap #10 copper wire, some boards and a few screws.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 08-19-2015, 07:44 AM   #5
Rabbit ears are commonly sold with coax cable output, so it should plug right in. But around here, all stations now transmit a digital signal. If your TV is more than roughly 8 years old, you probably need a digital to analog converter box to use the signal.
Where are you located?
Old 08-20-2015, 06:12 AM   #6
NorPlan's Avatar
Rewards Points: 224
Flat Screen TV.. Eastern Ontario..(Rural / Shadow of the Peace Tower..lol..) As I said we still have the Apple TV / Netflix hooked up.. I had thought there was a way of Clicking On another Setting to be able to bring up a local channel..
Old 08-20-2015, 06:30 AM   #7
There is a "setting". You will find an "input" setting for where the TV gets its signal. You have several different inputs --- probably one or more HDMI inputs, internet input, probably component input, possibly S-video input, possibly composite input, and an antenna input. On the TV menu, you can select which input you want to view from. So if you want to view over-the-air channels, you select to view from antenna. But you still need some signal going to that input, and to get a signal to the antennae input, you need an antenna.
Old 08-20-2015, 09:05 AM   #8
Rewards Points: 494
To make the input setting change from 'cable' to 'tv', use the original tv remote control.
If you can connect a 10 to 20 foot piece of old coax cable to the back of the tv and hold the other end near a window (tape it to the window?) facing the towers, you may get some transmission signal. can test by scanning for channels.
If you are willing to butcher the window end of the cable by cutting off the screw in part, peel back a bit of outer casing, pull some of the shielding shrands into a solid 'cable', separate that from the center solid wire and expose some, you've built a really crude antenna that should get an even stronger signal.
If you still have the satellite company cable going to your rooftop, you might consider using it on your chimney or other roof location with a small antenna or try it from your attic even. Just connect that cable to your tv's co ax antenna input.
Colbyt is right that any clear HD signal you can pull in over the air is not compressed in any way by a cable or satellite company and is therefore clearer.
diyorpay is offline   Reply With Quote
MTD Products 22 inch Snowblower drive cable Aggie67 Tools 0 03-02-2014 05:24 PM
Extending and covering phone cable in closet Dorado Electrical 5 03-28-2013 10:09 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 11:00 AM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 08:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
