#1 |
Delayed sound
Hopefully this topic hasn't been beaten to death here. When I watch my flat screen the sound is in sync with the picture. However when I try to listen through my surround sound the audio is a bit delayed. I am using a satellite receiver for tv reception. Now, when I watch a DVD or VHS (yes I still have VHS) the sound is NOT delayed through the surround sound. Any ideas? The delay is greater than a slight echo. If I am watching a show with dialog, the lip movement is far off from the audio, reminescent of the old dubbed movies.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#2 |
Average Joe/ex-Navy IC3
Delayed sound
Go through the settings for the A/V receiver and change the delay, along with making sure that the speakers are set for large if no sub, small if small like bookshelfs or cubes and using a sub.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you? |
#3 |
Delayed sound
Really need more info.
What TV and other gear are you using and how is it all connected? HDMI, Component, Toslink, Coaxial, etc, etc. |
#4 |
Delayed sound
Has nothing to do with the delay issue. All irrelevant.
#5 |
Delayed sound
I'll have to politely disagree...
How the various pieces of the system are interconnected is very relevant, and are the most likely reason for the problem mentioned. Think about it. Your idea of "change the delays" would now cause the audio for the DVD and VCR to be out of sync..... If the devices are not all connected in a similar manner, there can be audio sync issues. As an example I'll assume some things so you'll maybe understand what I mean: 1. TV is connected via HDMI, with a separate analog or digital feed to the AVR. 2. DVD is connect through the AVR via Component Video and Toslink or Analog cabling. 3. VCR is connected via Composite, or possibly Component and Toslink or Analog cabling. See the issue in item number 1? Possibly it's something else (different DAC's), but I'm betting on the system cabling. |
#6 | |
Delayed soundQuote:
#7 |
Delayed sound
PM me and I'll be happy to make a recommendation on your new AVR purchase.
There are a couple brands that you really want to stay away from.... |
#8 |
Delayed sound
We would all like to know what brands to avoid I think. Would you be so kind as to share?
#9 |
Delayed sound
It is more of a personalized opinion of some, than written fact. Some have been stating that the past few years of Onkyo's are bad, same for the past couple of years of Denon's, but nothing to say why, other than people have had problems with bad firmware updates (why they would, or how they did the update, is never stated), or that they went bad (usually cramped into a cabinet, or placed on a carpeted floor, or equipment stacked on top of each other will do that).
| Display Modes | |
| Sound Deadening Basement Ceiling | darrylshill | Drywall & Plaster | 4 | 06-01-2012 07:01 PM |
| No sound from speakers on rear projection tv | chewizzle2k9 | Electrical | 4 | 11-06-2011 10:42 PM |
| humming droning sound when AC is running | green.willow | HVAC | 2 | 07-07-2011 10:12 PM |
| Soundproof Windows | BlueJello | General Discussion | 3 | 11-30-2007 06:34 PM |
| What makes a quiet window? | Badfish740 | Building & Construction | 8 | 09-30-2007 11:22 AM |
