Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 03-07-2009, 10:14 PM   #1
Kap
Mowing my life away.
Dead pixels...bad screen-replacable? Trashed??
Sony Grand Wega 50 inch rear projection Model # KDF50WE655.
The screen looks as though it's been blasted by a shotgun. I'm not talking a couple dead pixels or even a couple hundred. More like thousand(s).
Fairly rapid progression. One or two appeared, then each day there were a few more.
It's impossible to watch. Everything else is fine.
Im guessing it's not worth replacing the screen? Would there be any possible value in this thing, or just haul it to the recycler?
Kap is offline   Reply With Quote
Old 03-08-2009, 10:14 PM   #2
Home Theater Guy
Sorry, say hello to the recycle guy.
Greg C is offline   Reply With Quote
Old 03-09-2009, 12:42 AM   #3
perpetualjon's Avatar
Naw, I'm sure someone on eBay would pick it up.
perpetualjon is offline   Reply With Quote
Old 03-09-2009, 03:30 AM   #4
Kap
That's what i figured. It's been parked in the garage for a year now.
I'm in Hawaii. It would cost at least a couple hundred to ship this thing. Maybe the lamp if it's still good. We've been cleaning out the garage, house storage...thinking of doing a yard sale. The stand might fetch a few bucks.
But then again, I love taking things apart to see what makes them tick. If this thing is a write off, I might learn something in the process.
Old 03-09-2009, 10:07 AM   #5
Home Theater Guy
Make sure that it has been unplugged for a few days before you pop it open. Then push the power button on the set a few times to discharge any capasitors that may still be holding a charge.
Old 03-15-2009, 10:55 PM   #6
bofusmosby's Avatar
Your set has a bad light engine. Sony has had a high failure rate on these, and on some models, has extended their warranty to cover this. I would suggest you call a Sony authorized service center, and give them the model number. They will then be able to tell you if this is still covered. If you go into it yourself first, this will void any chance that it will be covered.
BTW, when the set is unplugged, hitting the power switch a few times does nothing to discharge the capacitors inside. But, since this is not a CRT set, there shouldn't be much voltage stored inside.
bofusmosby is offline   Reply With Quote
Old 03-16-2009, 10:43 AM   #7
The light engine is not user serviceable and is positioned in the bottom of the set near the middle. It might have the appearance of a shoe box or a slide projector and has a lens assembly sticking out the top.
The lamp is user replaceable and snaps out quite easily. It typically is mounted in a cube frame perhaps the size of an old fashioned diskette box. If you trash the set you might take the lamp out and try to sell just it on eBay.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
