Copper Anti-oxidation Goo - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 09-24-2007, 05:59 PM   #1
Copper anti-oxidation goo
Probably way too anal, but I am wiring for speakers and because it will all be behind the wall I would like to avoid any oxidation of the copper. Any thoughts on compounds to prevent oxidation and keep my sound path pure?
kingkip is offline   Reply With Quote
Old 09-24-2007, 08:50 PM   #2
Media Guy
Anal Wiring
You are concerned about the exposed copper corroding? If that is your concern, why not solder the connections and forget about it. Remember - the part of the wire that is in contact with the connector can't get air to corrode. If you have enough moisture in the wall to cause corrosion, I think you will have more than speaker problems .
mediatech is offline   Reply With Quote
PEX with copper stub-outs RippySkippy Plumbing 6 05-24-2007 07:32 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
Questions about copper tubing... SDeeter19464 Plumbing 3 04-21-2006 09:11 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
