Controls For Media Closet In Basement. - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 03-26-2014, 05:39 PM   #1
Rewards Points: 152
controls for media closet in basement.
I am doing my basement. I want to make a media closet in the basement. Have all my wires in that closet. I want to put the satellite, ps3, surround sound boxes in the closet. I want everything clean at the tv.
The problem I am noticing is how will I control all the entertainment boxes that will be in the basement when the TV is upstairs?
I have seen on the Internet, some app that can control the devices through WIFI. That would mean for me that I would need to upgrade every box and TV to Internet capable devices in my house. Is their another method?
humberguy is offline   Reply With Quote
Old 03-26-2014, 10:52 PM   #2
Bill Kearney
Rewards Points: 1,174
Use a wired infrared repeater. A pickup goes up near the TV, wires lead back to the repeater block near the gear. IR emitters go from that block to the front of each device. CAT5 wire works fine for this sort of thing. There have been many schemes for doing this but in the end using a standalone wired IR repeater is the tried-and-true most reliable. Trust me, I've tried just about EVERYTHING else.
wkearney99 is offline   Reply With Quote
Old 03-27-2014, 04:54 PM   #3
Rewards Points: 152
Thank you. You saved me a lot of headaches. One more question. Can I buy a universal remote to control the receivers so I can run one wire?
Old 04-02-2014, 03:30 PM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
You may run into issues with your PS3 controllers, depending on how far away and what materials the signal must pass through.
You only run one wire (a CAT5 or 3.5mm audio cable) for the IR repeater. It just sees any IR signal and repeats it, so if you have 1 remote or 50 they will all work with the IR repeater.
Example:
http://www.amazon.com/IR-Repeater-System-Control-Theater/dp/B0016PM63W
That one uses a 3.5mm audio cable for the IR receiver. There is a 50' extension available on the same page for about $6.
hyunelan2 is offline   Reply With Quote
Bedroom Closet Organizing trixie2396 Interior Decorating 10 09-19-2013 07:14 AM
Options for new basement Perry401 Building & Construction 8 02-27-2013 10:22 PM
Basement bedroom framing options Mesoneer Remodeling 8 01-24-2012 12:47 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
