Components Too Hot From Fireplace - Home Theater - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-17-2013, 12:31 PM   #16
JPL
Number 1:Bad design is still bad design, regardless of your fireplace installers qualifications.
Number 2: I'm well aware of fan operation. A fan is a fan. They move air from point to point- if you suck hot air out, you need a cool air inlet somewhere to flow from inlet to exhaust.
Number 3: I haven't resorted to name calling here.
JPL is offline   Reply With Quote
Old 10-17-2013, 09:01 PM   #17
Rewards Points: 140
i agree with JPL. unless you pipe in cool air from somewhere else, your just circulating hot air. after all, heating air is what a fireplace is meant to do. i have read about tv's melting from being over fireplaces.
Fix'n it is offline   Reply With Quote
Old 10-18-2013, 12:42 AM   #18
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Zero clearance is a term used to describe a certain fireplace’s ability to be enclosed completely by combustible building material that can be positioned right up against the body of the fireplace. That is the back, top, bottom and sides. The front area is designed to radiate heat and therefore must be given adequate clearance to combustibles. In this case, objects such as furniture, should be kept a minimum of 48″ away.
ALL electronic components I have ever been exposed to have heat sinks and or fans which dissipate heat to the air. If the air is warm or hot the heat cannot dissipate.
Like Fix and JPL are is saying...
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 09:09 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
