Components Too Hot From Fireplace - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-10-2013, 04:31 PM   #1
Rewards Points: 97
Components too hot from fireplace
I have a built in fireplace mantel/entertainment center with space above the fireplace to put different components(directv receiver, ps3, etc)
The problem is after a couple hours of use the area gets too hot for the equipment. IS there an insulator I could use to almost stop the transfer of heat. Would using just regular foam insulation work??
I have attached a picture of the area in question
BigRedFan is offline   Reply With Quote
Old 10-10-2013, 05:50 PM   #2
Rewards Points: 6,652
Foam equals off gassing, when gets hot, or if it melts. What is the measured temp that you are getting, where the components and tv are sitting? You can use a Grill thermometer with remote sensor, to give you that info.
Old 10-10-2013, 07:40 PM   #3
chitownken's Avatar
Rewards Points: 510
Could you move the components to the side opposite the sub? Would get less heat from the fire there.
chitownken is offline   Reply With Quote
Old 10-10-2013, 08:53 PM   #4
I just noticed that sub. Bad placement for it. It should be back by the seating area, or on the wall, near the seating, not in that cabinet.
Really need to know what temps they are getting, before any suggestions can be made.
Old 10-10-2013, 09:13 PM   #5
Rewards Points: 140
when i was doing the A/V thing. i read some stories about just how bad it was to put any gear over/around a fireplace. just say'n...
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
dabeast (10-11-2013)
Old 10-11-2013, 04:23 PM   #6
Rewards Points: 97
will have to do that next time we run it. In all honesty it was after beuing run for 5 hours. Highly unlikely we run it that much.
My other thought was to use some spacers(like footers) on the side and elevate the components off the wood so it has less direct heat
Old 10-11-2013, 05:08 PM   #7
Rewards Points: 2,630
McMaster Carr is a good place to look for various types of insulation.
http://www.mcmaster.com/#thermal-insulation/=ow6sih
The other thing that will help is to get good airflow through the compartments. It does not look like you have glass in the front, so that is good (that would really trap the hot air). Possibly you can find a few small decorative grills, that you can mount above the components, to let hot air escape.
SPS-1 is offline   Reply With Quote
Old 10-12-2013, 11:39 AM   #8
K&B Designer
Live_Oak's Avatar
I have to say that the firebox surround doesn't look like it's built of fire resistant materials to me. If you're getting enough heat transfer to adversely affect electronics, that's a double ?? as to how the whole thing is constructed. You might want to contact your local fire department for an inspection. Better you get red flagged and have to rebuild it correctly than you burn your house down.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 10-12-2013, 09:31 PM   #9
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Zero clearance is to combustibles...
Most electronics in their literature tell you ambient temps that they can work in. That close to fireplace I'm sure isn't in ambient range.
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 10-16-2013, 02:05 PM   #10
Rewards Points: 97
not sure if directed to me. The fireplace was built to the specs required. It is a zero clearance fire place there is 1.5 inches on either side of the firebox and about 2 inches ontop
Old 10-16-2013, 02:39 PM   #11
Rewards Points: 97
http://www.coolerguys.com/840556093145.html
will be trying something like this to keep the componnets cool
Old 10-16-2013, 08:51 PM   #12
JPL
Bad idea, really bad idea. I've been doing A/V for 23 years. Don't insulate it- move it all.
JPL is offline   Reply With Quote
Old 10-16-2013, 09:13 PM   #13
Rewards Points: 97
Then I'm sure you saw my last post about using component cooler fans
Old 10-16-2013, 10:05 PM   #14
JPL
So- where do the fans get the COOL AIR? Bad idea, bad design=bad result. Fry your stuff- it's your $$$. Hopefully you won't endanger anyone, or burn your house down.
Old 10-17-2013, 10:35 AM   #15
Rewards Points: 97
nice comment.
First of all let me start.
This is zero clearance insert fireplace. The mantel was built and exceeds the reccomended specs. The fireplace was installed by a licensed installer who said as much about the mantel.
Second,
For being an AV guy you obviously dont know how Cooler Fans work. These fans work by expelling out the warm air. They do not blow air in but instead blow air out of the cavity. Thus creating a cooler enviroment
Third,
Dont be a tool and say things about burning houses down
Fireplace reno help, wood to gas fireplace jsunsun Building & Construction 4 01-15-2013 09:09 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
