Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 03-29-2010, 12:58 PM   #1
Question
component (RCA) cables behind the wall
i am wiring my projector to the DVD player on the other side of the room and plan to do it behind the wall and use wall plates and RCA connectors. my question is: is there a special grade of component cable to go behind the wall or can i use the same kind that goes outside and what the specification for that cable is ?
Old 03-29-2010, 02:31 PM   #2
Coconut Pete's paella!
CoconutPete's Avatar
I don't know if you shop on monoprice ever (it's a great website) but I've never seen RCA cables labeled as "in-wall". Obviously power cable can't be tucked in the wall, and HDMI cables have to be "in-wall" rated in order for it to be right, but I can't find anything RCA related that mentions the wall.
CoconutPete is offline   Reply With Quote
Old 03-31-2010, 08:55 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Use Coax (RG-6) for your RCA cables. Not only would be shielded, but would be best solution. The termination is done just like a Coax end, just that you would be using a RCA connector that screws onto the coax connector.
The Following User Says Thank You to gregzoll For This Useful Post:
amakarevic (04-01-2010)
Old 04-01-2010, 12:08 PM   #4
Question
hi, is this the same kind of cable as is used by the cable company to bring TV/internet to my house ?
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
