Co-axial To Rca Conversion - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 04-10-2011, 10:59 AM   #1
Rewards Points: 274
co-axial to rca conversion
I have a wall mounted tv that connects to dish box via hdmi cable inside wall. I have a co-axial cable that runs inside wall that is not being used. Can I somehow convert the coax cable to a rca (red, yellow, white) cable to hook up dvd to tv, or do I need to fish rca thru wall (harder to do)
ugabulldog is offline   Reply With Quote
Old 04-10-2011, 11:30 AM   #2
Rewards Points: 1,442
You can put RCA plugs on a coax cable (both ends) and it will work fine for audio and will usually work fine for video. But you need three of them, one for the red, one for the white, and one for the yellow.
If you are going to fish more cables, better to install five "RG6" type cables, three for the video with red, green, and blue RCA jacks plugged into the "component video" jacks and the other two for audio -- one for white and the other also for red RCA jacks. And while you are at it, fish an HDMI cable and an optical sound cable alongside the others.
If you know that the cables are of unequal quality, use the best one(s) for the video.
Note: Do not put the RCA plug on just one end. There are no working standard combinations of equipment where one cable end goes to a coax stud jack and the other end goes to an RCA jack.
Old 04-10-2011, 12:11 PM   #3
Remodeler
Rewards Points: 314
An RF modulator will convert the composite (yellow, red white) signal to RF that can be carried on the RG6 cable.
These were made to connect DVD players to older TV's that did not have the composite jacks. They cost about $15-$20.
iamrfixit is offline   Reply With Quote
Old 04-11-2011, 03:58 PM   #4
Citrix & Cisco Ops
iammrfixit's post hit the nail on the head... just one caveat to add: RF Mods are a huge "You get what you pay for" area of electronics. If you buy the cheapest one you can find, it will probably be apparent
RedHelix is offline   Reply With Quote
Gas Valve 7200 IPER-S7C LP Conversion mikefrommi HVAC 5 03-06-2011 10:40 PM
Installing elevated wood floor in garage conversion. FWatty Flooring 0 02-22-2011 04:49 PM
Garage Conversion SDEngr Remodeling 13 06-01-2010 05:11 PM
Vacation Home garage conversion imgarret Remodeling 0 01-30-2010 09:15 AM
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 04:57 PM
