Channel Modulator - Home Theater - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 10-17-2007, 11:47 PM   #1
Channel Modulator
I have a Channel Plus, 4 channel modulator. I have all of my A/V components in a closet. I have two indentical DVR's from Time Warner Cable. So both DVR's have the same IR signal. The Channel Modulator emits the same IR signal to both DVR's. How do I operate one DVR, with my remote without effecting the other. Any ideas? Am I making any sense?
BigE is offline   Reply With Quote
Old 10-18-2007, 11:27 PM   #2
Rewards Points: 1,456
Your best alternative is something like the Universal Remote Controls MX850 or MX900 paired with a MRF300 or MX350. MX900/MRF350 combo retails at $650.00 US
Unfortunately these are professional level products requiring PC programing (and the software to do such) which are not available to the general public as they are not DIY items.
What you need is IR routing, and there is no cheap way to accomplish that.
Possibly there are some other not quite as good, lessor known brands that have the capability....
Google RF/IR routing remotes...
ktkelly is offline   Reply With Quote
Old 10-29-2007, 12:28 PM   #3
TurningColorz's Avatar
Can you just cover the "eye" of one unit?
Or, maybe a shield on the "eye" one unit, or both, to focus the remote signal only where you point it. Also, it might help to have some distance between the 2 units. If they both operate on the same remote, your choices are limited.
Mike
http://www.TurningColorz.com
TurningColorz is offline   Reply With Quote
Old 11-11-2007, 09:09 PM   #4
Tivos have a "unit" code that you can set (1-4) so you can use multiple units in the same closet. I assume that your DVRs will have the same function. What are you using for IR distribution?
memjeff is offline   Reply With Quote
Old 11-11-2007, 09:15 PM   #5
avsforum.com might be a better place for this
Resilient Channel For Basement Ceiling Stingray Remodeling 7 02-07-2010 01:14 PM
Window casings around window with integrated J channel? sandyman720 Building & Construction 11 10-02-2007 02:15 AM
Brick up against sliding patio door with J Channel? sandyman720 Building & Construction 2 09-28-2007 08:47 AM
8" cedar channel siding pedro8238 Building & Construction 2 08-24-2006 02:16 PM
