Can I Mount My Flatscreen Inside The Fireplace Opening? - Home Theater - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Home Theater
Old 03-04-2013, 02:03 AM   #16
Is the TV installed inside the fireplace?
We have the same situation. The room only has one wall for furniture so the TV has to go on the fireplace wall. The fireplace has a raised hearth and the mantel is high, so to view the TV above the mantel would require recliners. Fortunately, since the hearth is raised and the mantel is high we can mount the TV at about 3 1/2-4 feet from the floor. The TV is a 60" so it will be easy to view while seated. We thought about building a wood box inside the fireplace as well and adding a small glass cabinet underneath the TV for the DVR and Cable box.
We have two other fireplaces so we are not worried about not being able to use one of them. However, we do want to make sure that we can put the fireplace back to its original condition for resale.
Have you completed your project? Or has anyone else installed a TV into a fireplace? Pictures would be nice. Thanks
Patti S is offline   Reply With Quote
Tags
fireplace
3D LED TV above fireplace - mounting artcardriver Building & Construction 7 01-02-2011 01:21 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 02:37 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 09:52 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
