Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Home Theater
Old 10-10-2010, 12:31 PM   #1
Jack of all - master none
hyunelan2's Avatar
Cable wiring for antenna + internet
Here is the short version:
I currently have Comcast for cable TV and internet. I am going to get rid of their cable service, but keep the internet service. I have built and installed an HD over-the-air (OTA) antenna in my attic.
I have run coax from my antenna down to the basement where Comcast service enters the house, hits the splitter and goes out to the wall outlets in the house. Since I will still need Comcast to be carried over those lines for internet, how do I tie in both together? Is this possible?
(If not, I guess I will have to get another splitter for the antenna, then hook all the TVs up to that splitter, and leave the ports that are needed for internet hooked up to the Comcast splitter.)
hyunelan2 is offline   Reply With Quote
Old 10-10-2010, 01:56 PM   #2
nap
You talking to me?
nap's Avatar
where is your modem and router for your internet? Since a Comcast modem has a coax input and an ethernet or USB output, how are you utilizing the internet to multiple locations now?
Unless you are using multiple modems, you would not have coax to each room for internet use.
Old 10-10-2010, 05:51 PM   #3
hyunelan2's Avatar
Ive got just one modem - then hooked up via Ethernet to my router. CAT5 serves connections from there. The room with the modem has a pass-through coax output which goes to a TV, but I guess I can deal with that one separately.
Sounds like my best bet is to run Comcast straight to my office (room with the router), and jack the antenna input into the splitter that serves the rest of the house.
The Following User Says Thank You to hyunelan2 For This Useful Post:
gregzoll (10-10-2010)
Old 10-10-2010, 07:12 PM   #4
nap
You talking to me?
nap's Avatar
what I would typically do is take the main cable to the distribution equipment. At that point, split the line with one going to the TV distribution and a second line to the internet modem. At that point, if you need a switch or if the modem/router has enough ports, simply plug your ethernet cable that you have also run to the basement into the modem/router.
depending on where you set your head end equipment, you will have to adjust to fit your layout.
Old 10-10-2010, 09:08 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
You will not be able to mix OTA with the Internet signal from Comcast.
The signal from the antenna needs to stay a separate run to the tv sets. That means a direct coax from the outside drop for cc to your modem period.
Old 10-10-2010, 10:10 PM   #6
nap
You talking to me?
nap's Avatar
there is no antennae. He has a single coax running to the house. It carries both broadband internet and cable television. You split them with one feed going to the modem and the other to the television distribution.
Old 10-11-2010, 09:31 AM   #7
gregzoll's Avatar
From the OP."I am going to get rid of their cable service, but keep the internet service. I have built and installed an HD over-the-air (OTA) antenna in my attic."
May want to throughly read it again nap. As for splitting if a person has both tv & internet, using the wrong splitters can make a mess of the signal, which accounts for the majority of the trouble calls for catv techs, incorrect equipment placed on the line by the end user/home owner/renter.
Old 10-11-2010, 10:05 AM   #8
hyunelan2's Avatar
Maybe this will clarify what I have now, what I wanted to do, and what I think I'm going to have to do.
EDIT: Note, I forgot to remove "(unattached)" from the second 2 drawings for the HD antenna - the HD antenna would be attached in those configurations.
Old 10-11-2010, 10:29 AM   #9
gregzoll's Avatar
There was nothing to clarify. You are wanting OTA instead of catv for your tv signal. You just need to use the coax that is already in place for those sets that you previous had hooked up to your catv provider for tv viewing. As I mentioned before, you just need to hook the coax from the provider directly to your modem period, without having the OTA signal in the mix.
We are talking two different things here period. What you have is plain and simple, you want to pay more for your internet service, and watch limited program from the air waves through archaic technology. BTW, there is no such thing as a HD antenna, it is just a UHF antenna.
Old 10-11-2010, 10:37 AM   #10
hyunelan2's Avatar
It seems there was some confusion here, otherwise your last post wouldn't have been necessary.
You must work for Comcast huh? $20 more for their internet service, $95 savings for getting rid of their TV = $75 net monthly savings. Everything that I could watch on Comcast is conveniently available through Hulu on my HTPCs. I watch everything DVR'd a day or two later anyway, so the 1-day Hulu lag is not a big deal. I just need OTA broadcast for sunday football and the morning/evening news.
Furthermore, Comcast's HD signal is horrible vs. OTA picture quality. The picture is compressed to squeeze more channels into their pipe, which results in motion blur. Switching back and forth between the two, even my wife can notice (which says something). I also do not like the fact that we now have to have the digital transport converter boxes on every TV in the house, which conveniently kills HD from that TV, unless you pay more per month for additional HD boxes.
EDIT: I should also add, that typically if you keep limited basic TV (get rid of digital), they will not raise your internet rates, and the cost is cheaper than the surcharge on only having internet. I want to see if everything works to my satisfaction OTA before I move forward with this though.
Old 10-11-2010, 11:48 AM   #11
gregzoll's Avatar
Work for comcast, no. Where did you get that from what was posted? What you are trying to do is nothing that takes a whole lot of thought, and is done all the time. You want Internet from a provider, regardless if it is DSL, T1, Dial-up, Satellite, CATV, and you want tv viewing, regardless if FiOS, OTA, Satellite, U-Verse, CATV. These are two separate services regardless what you think and need to be kept separate from each other period.
OTA regardless if on Coax or 300 ohm flat ribbon goes to the tv sets, and Internet from your CATV provider comes in on their coax to the direct point where there modem will be located. You can not mix the two services on the same coax, because it will never work period. Only way to mix tv & Internet, is if they are coming in from the same provider through their lines.
As for Picture Quality, 99% of the time, it is the tv set that the signal is viewed on, not the service provider. I have had Comcast, and now have ATT U-Verse, and you really can not tell the difference between the two. Now if you compare both against satellite, you can tell a difference in that Satellite PQ is very poor for their HD & SD channels. Again, does not take a lot of technical thinking, and does not take an engineer to explain, or think of the process of what you are wanting to do.
Old 10-11-2010, 11:53 AM   #12
hyunelan2's Avatar
This is all I needed to know. period. period. You don't need to be a jerk about it. Since the antenna isn't really creating a "signal," it's just wire, after-all, I wasn't sure if you could just jack an antenna in with the rest of the feed, and have an antenna there for the TV tuner could use, plus the comcast signal over the coax that a modem/DTA-box could read.
Old 10-11-2010, 12:01 PM   #13
hyunelan2's Avatar
Agree on TV picture quality - but when you compare 2 signals on the same TV, that eliminates that possibility. Providers also vary by area. Comcast here in Chicago is probably not the same as it is wherever you are. There have been plenty of complaints about Comcast's degraded HD signal here. It looks clear until there is a lot of motion, then you see some drop-out, especially in the background. Here's a link to some examples
I'd love to give U-verse a go, but is not available in my area.
Old 10-11-2010, 12:41 PM   #14
gregzoll's Avatar
I would not trust opinions from AVS Forums, since majority are too OCD when it comes to over thinking PQ. As for U-Verse, yes there is motion blur with sports, you are going to have that on any provider regardless if OTA, or through a pay service.
Old 10-11-2010, 12:42 PM   #15
gregzoll's Avatar
The signal is picked up by the antenna, and distributed by the coax/flat ribbon in the house through an amplifier & splitter. Same way that is done by CATV providers.
wiring zone valve help paul1968uk Electrical 5 03-31-2010 11:34 AM
slow....................internet RichyL PC Repairs & Upgrades 16 10-20-2009 08:57 AM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 10:04 AM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 01:16 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
