Cable wiring for antenna + internet
Here is the short version:
I currently have Comcast for cable TV and internet. I am going to get rid of their cable service, but keep the internet service. I have built and installed an HD over-the-air (OTA) antenna in my attic. I have run coax from my antenna down to the basement where Comcast service enters the house, hits the splitter and goes out to the wall outlets in the house. Since I will still need Comcast to be carried over those lines for internet, how do I tie in both together? Is this possible? (If not, I guess I will have to get another splitter for the antenna, then hook all the TVs up to that splitter, and leave the ports that are needed for internet hooked up to the Comcast splitter.) Thanks |
where is your modem and router for your internet? Since a Comcast modem has a coax input and an ethernet or USB output, how are you utilizing the internet to multiple locations now?
Unless you are using multiple modems, you would not have coax to each room for internet use. |
Ive got just one modem - then hooked up via Ethernet to my router. CAT5 serves connections from there. The room with the modem has a pass-through coax output which goes to a TV, but I guess I can deal with that one separately.
Sounds like my best bet is to run Comcast straight to my office (room with the router), and jack the antenna input into the splitter that serves the rest of the house. |
what I would typically do is take the main cable to the distribution equipment. At that point, split the line with one going to the TV distribution and a second line to the internet modem. At that point, if you need a switch or if the modem/router has enough ports, simply plug your ethernet cable that you have also run to the basement into the modem/router.
depending on where you set your head end equipment, you will have to adjust to fit your layout. |
You will not be able to mix OTA with the Internet signal from Comcast.
The signal from the antenna needs to stay a separate run to the tv sets. That means a direct coax from the outside drop for cc to your modem period. |
From the OP."I am going to get rid of their cable service, but keep the internet service. I have built and installed an HD over-the-air (OTA) antenna in my attic."
May want to throughly read it again nap. As for splitting if a person has both tv & internet, using the wrong splitters can make a mess of the signal, which accounts for the majority of the trouble calls for catv techs, incorrect equipment placed on the line by the end user/home owner/renter. |
3 Attachment(s)
Maybe this will clarify what I have now, what I wanted to do, and what I think I'm going to have to do.
EDIT: Note, I forgot to remove "(unattached)" from the second 2 drawings for the HD antenna - the HD antenna would be attached in those configurations. |
There was nothing to clarify. You are wanting OTA instead of catv for your tv signal. You just need to use the coax that is already in place for those sets that you previous had hooked up to your catv provider for tv viewing. As I mentioned before, you just need to hook the coax from the provider directly to your modem period, without having the OTA signal in the mix.
We are talking two different things here period. What you have is plain and simple, you want to pay more for your internet service, and watch limited program from the air waves through archaic technology. BTW, there is no such thing as a HD antenna, it is just a UHF antenna. |
Furthermore, Comcast's HD signal is horrible vs. OTA picture quality. The picture is compressed to squeeze more channels into their pipe, which results in motion blur. Switching back and forth between the two, even my wife can notice (which says something). I also do not like the fact that we now have to have the digital transport converter boxes on every TV in the house, which conveniently kills HD from that TV, unless you pay more per month for additional HD boxes. EDIT: I should also add, that typically if you keep limited basic TV (get rid of digital), they will not raise your internet rates, and the cost is cheaper than the surcharge on only having internet. I want to see if everything works to my satisfaction OTA before I move forward with this though. |
Work for comcast, no. Where did you get that from what was posted? What you are trying to do is nothing that takes a whole lot of thought, and is done all the time. You want Internet from a provider, regardless if it is DSL, T1, Dial-up, Satellite, CATV, and you want tv viewing, regardless if FiOS, OTA, Satellite, U-Verse, CATV. These are two separate services regardless what you think and need to be kept separate from each other period.
OTA regardless if on Coax or 300 ohm flat ribbon goes to the tv sets, and Internet from your CATV provider comes in on their coax to the direct point where there modem will be located. You can not mix the two services on the same coax, because it will never work period. Only way to mix tv & Internet, is if they are coming in from the same provider through their lines. As for Picture Quality, 99% of the time, it is the tv set that the signal is viewed on, not the service provider. I have had Comcast, and now have ATT U-Verse, and you really can not tell the difference between the two. Now if you compare both against satellite, you can tell a difference in that Satellite PQ is very poor for their HD & SD channels. Again, does not take a lot of technical thinking, and does not take an engineer to explain, or think of the process of what you are wanting to do. |
I'd love to give U-verse a go, but is not available in my area. |
I would not trust opinions from AVS Forums, since majority are too OCD when it comes to over thinking PQ. As for U-Verse, yes there is motion blur with sports, you are going to have that on any provider regardless if OTA, or through a pay service.
The signal is picked up by the antenna, and distributed by the coax/flat ribbon in the house through an amplifier & splitter. Same way that is done by CATV providers.
| All times are GMT -4. The time now is 12:56 AM. |
